TWRP for Amlogic devices.
    Originally posted by soldiaz View Post
    Well, you are talking about remote cfg used in recovery, right? To be honest I am using an Airmouse but I know there is remote cfg for the recovery. If you unpack an .img you can access recovery and replace with working remote cfg in case remote code is not part of DTB...
    No, the air mouse and the IR are using different drivers. Air mouse is working for sure, I used that too. But IR remote is not working despite after I added the proper remotecfg, remote.conf and edited the run script.
    So I am asking if anyone had use a TWRP with a working IR remote. Just tell me where is the image I can figure out the rest. TQ.
      it's any way to put Twrp on this Firmware
        Yes Airmouse works always!
        If you have working remote in system then just copy over the working remote cfg and replace the remote cfg in recovery. You can do that using Amlogic tools when you unpack the image
          I did that already and it is not working that's why I am asking for help here. I suspect it is the setup issue. So I am not asking for "theories", I am asking for a real life working twrp image which has an IR remote proven to be working for your boxes.
          This is not asking for help for the correct remote.cfg file, this is asking for help about the correct setup needed to get IR remote working in TWRP.
            hehe, alright
              Hello,
              I can't find the right TWRP recovery for my x96 with ap6330. can you help me?
              Thank you
                U can use temporary recovery from here.
                  Thank you for your reply; but it's the right version of TWRP that I can't find. You can see my box at this link: https://www.maniashopping.it/product...odi-tv-box-4k- iPTV-decoder-top /. It has an amlogic s905x processor and is not the X96 mini, which has a slightly different processor. I have seen that [TWRP] S905X2 - TWRP Recovery 3.2.2 is fine for the x96 mini. I haven't tried it yet, but I think it doesn't work on mine.
                  I would be very grateful if you could answer me.
                  Thanks again so much
                    * This is only a temporary boot TWRP, your stock recovery will be intact after a reboot
                    Above TWRP is universal, will run on (all) Amlogic devices and does not make any changes to your sistem, its "live" version.
                      Sorry, but the file is: twrp.u211-3.2.3-1-signed.zip?
                        This is the right one; TWRP_322.zip
                          If I click on TWRP_322.zip it tells me:
                          Information
                          You are not authorised to download this attachment.
                            Great mAtvXk !!! I managed to download the file, I tried it and it works perfectly !!!
                            I wanted to ask you another thing; since I would like to buy another TV box, if it doesn't have an amlogic processor, is there a possibility to find, as in this case, a universal TWRP for the new processor?
                            Thank you so much
                              No
                                Stay with Amlogic
