Thanks in advance
TWRP for Amlogic devices.
Originally posted by k_masterz View Postwhere do i get TWRP for p212 or MXQ PRO 4K S905X ?
Guest
Here's a TWRP recovery (v3.1.1-0) I just built for 64-bit Nougat on the q201 reference board (e.g. Beelink GT1, Alfawise S92, etc.): twrp.q201_64-3.1.1-0.img
The source is also available on my GitHub repo.
I have a generic H96 Pro AmlS912 with 3GbDDR3 / 16Gb and I used both android 6.0.1 and android 7.1.1 a32bit (superceleron 7.1.1 scv3) and 7.1.1 64bit (stockrom).
There are 5 twrp recovery available.
3 for Android 6.0.1
1 for Android 7.1.1 32bit SCV2/3
1 for Android 7.1.1 64bit StockRom
In android 6, recovery twrp has problems managing backup and recovery of system and userdata partitions. The restore ends with the error: EXTRACT TARFORK () process ended with error: 255. In android 7, both recoveries are working correctly.
But in Android 6 I noticed this:
TWRP 3.0.2-0 by Abdul
backup system ok
restore system failed
backup userdata ok
restore userdata ok
TWRP 3.1.0-0
backup system ok
backup userdata ok
restore userdata failed
TWRP 3.1.1-0
backup system ok
backup userdata ok
TWRP 3.1.0-0 in Superceleron SCV2
backup system ok
backup userdata ok
restore userdata ok
The backup of /userdata executed with TWRP 3.0.2-0 by Abdul is also properly restored by the other TWRP recovery. So: the problem is in the backup creation phase and not in the restore step?
Does anyone have an idea or know how to solve this problem?Last edited by devilz-wolit; 24 July 2017, 10:42.
Guest
I believe these are all due to incorrect partition sizes set in the BoardConfig.mk. Frankly, the fact that TWRP expects us to set this in the makefile seems completely wrong to me, since partition sizes will vary from model to model...and even between different SKUs of the same model. Instead, TWRP should determine the partition sizes dynamically.
Originally posted by Magendanz View PostI believe these are all due to incorrect partition sizes set in the BoardConfig.mk. Frankly, the fact that TWRP expects us to set this in the makefile seems completely wrong to me, since partition sizes will vary from model to model...and even between different SKUs of the same model. Instead, TWRP should determine the partition sizes dynamically.
Guest
Originally posted by devilz-wolit View Post...but did not find inside the BoardConfig.mk file to edit it. What can I do?
Originally posted by Magendanz View PostWell, it's a makefile, so it's mainly compiler directives and won't be contained in the resulting image. Details are here: https://forum.xda-developers.com/sho....php?t=1943625
I have never created or edited twrp. We'll see what's coming out.
Edit:
I tried to do a version 3.1.1-0 porting and I got this:
Backup system : ok
Restore system : failed
Backup data : ok
Restore data : ok
But system partition failed immediately to restore with error 255Last edited by devilz-wolit; 26 July 2017, 11:23.
Guest
A new TWRP 3.1.1-0 build for Amlogic p21x reference boards (e.g. MECOOL M8S Pro+ running 64-bit Android 7.1.2) is available for testing here: twrp.p21x-3.1.1-0.img
Also, for devices that haven't yet been rooted, I've included a signed update here: twrp.p21x-3.1.1-0-signed.zip
To install the update, just copy the .zip file to an SD card, run the UPDATER app, hit Local Update and select the local .zip file. No need to wipe data or cache. The machine will reboot and install my TWRP recovery, just like an OTA system update. With TWRP now installed, you should be able to root the device using the recovery flashable .zip files for SuperSU or Magisk.
And for those brave souls who want to make changes or build for other Amlogic devices, I've provided the source on GitHub here:
If you spot any issues, please let me know via PM.
The real partition size of my generic h96 Pro with android 6.0.1 is 1610612736
I tried to change it, but obviously something wrong.
This is twrp 3.1.1-0 for android 6.0.1 with working restore data but with bad system restore.
Can you help me?
Guest
Sorry, but I just don't have the time to generate custom builds for all the possible permutations of partition sizes on all these devices. As I said before, we need a fix in TWRP to dynamically read the partition sizes rather than defining them at compile time in BoardConfig.mk.
Hi all,
I noticed in newer releases of TWRP, we can no longer backup internal storage (app data). Is there a way to be able to do this again through recovery?
Much thanks.
#1378.1Guest commented04 August 2017, 00:58Editing a commentSee above comments about setting the partition sizes in the makefile. That means I have to pick a specific partitioning scheme for the feature to work. We need a TWRP feature that sizes dynamically. I've published the project on GitHub, though, so you can make a TWRP recovery specifically for your box.
Much thanks Magendanz!
I've found your project on GitHub... I have no problem doing the work at all and even posting it here if everything works and to be honest, I've actually always wanted to learn how to compile my own recoveries.
Now you're probably going to hate me for this but is there a tutorials on how to do this from start to finish? Preferably on Windows?
Thanks again for all of your help.
Guest
There are currently 2644 users online. 0 members and 2644 guests.
