Bootloader doesn't appear as an option to backup ?
Everything seems OK, remember that env,misc and reserved will not be backup up( there is no need for it) so i will remove those entry.
For security you should back up boot and/recovery and check if they are correct, i might have assign them incorrectly. Or upload them that i can check.
If this image works as expected them i will make new ones for more models.
PCB "M8 V5_0 20141119"
Now Bootloader is OK, thanks.
but that version of TWRP still not start at my other model of M8 TV Box - PCB "M9&M8_V0.92 201-03-12", while any other version of TWRP for M8 and K200 start OK (but only one of them correctly detects all partitions)
can you add some fixes to TWRP_2.8.7.0_K200_Testing_emmc.img for compatibility with my another M8?
i want to copy Firmware via TWRP from my one M8 model (PCB "M8 V5_0 20141119") to another my M8 model (PCB "M9&M8_V0.92 201-03-12").
here is info from ADB partitions via another my M8 model (PCB "M9&M8_V0.92 201-03-12") using that version TWRP: TWRP_2.8.7.0_M8N.img
