TWRP for Amlogic devices.
    Took a chance, and installed latest version of TWRP, all good, went into recovery and made a backup. even changed the ROM to a Tronsmart MXIII (115k4- even with the bad spelling!) ROM is working OK,and its good to have a backup just in case.many thanks.
      Has anyone checked 2.8.7.0 on Minix X-8H successfully ? Although it goes to TWRP, it doesn't see any of the folders I have on the sdcard.
        Hello All, this is my first time posting to this forum. I have an MXiii S802 box that I want to install TWRP recovery on, but I'm not even sure which build the box is. I know its an Amlogic S802 2 gig box. But the build number under settings is: KOT49H.20150815 test-keys? which version of TWRP would I use and which install method? when I renamed TWRP image to recovery.img and put it on the sdcard the sdcard didn't see it...
        thanks for any help on this.
          Which version should I use for MXiii S802 2 gig box?
          thanks
            dkholm56
            try the following on page one...
            TWRP 2.8.7.0 K200 - Beelink S82/S82B/S82H+Ap6210/Ap6330 and MXIII(1G&2G DDR)+AP6181/AP6210/AP6330 and Tronsmart S89/S89H (114k4) - Confirmed
              Thanks for the reply. That is the one I've been trying. For some reason the MXiii stock recovery will not see the image file on the sdcard or a usb thumb drive. Any suggestions as to why.
              thanks
                Originally posted by Zybex74 View Post
                for example i have that firmware: k200-ota-20150613
                it included [ATTACH]n535561[/ATTACH]
                so can you check that file and make some fixes in it ?
                ota update formats partitions. If you are repairing then use Amlogic USB Burning Tool http://chinagadgetsreviews.com/downl...-v2-0-4-3.html and find a recovery that has usb instead of sd in description, example Em9_ap6330_2g8g_150203_usb.rar. Extract the file aml_upgrade_package.img and burn it to sdcard, hope it works.
                ​Archos Gen9 A80S cm-11.0
                Kindle Fire 2 cm-11.0
                  I cant seem to get into stock recovery (it's been like that ever since I got the box) the box is M8 Ott s802 with 2gb ram. whenever I try one of the recovery.img's in the 1st post it either freezes on the amlogic logo on freezes at a black screen?
                    - adb shell 'dd if=/path/to/recovery.img of=/dev/block/recovery ;sync;sync'
                    does this command work to install TWRP recovery? If so what is the actual command? do you include the quotes? I can't get the stock recovery to recognize recovery.img no matter what I do...I have the MXiii S802 2 gig box. I have even tried Flashify and TWRP Recovery Manager....
                      Amlogic M802 K200 2gb Ram
                      Confirm previously
                      TWRP 100℅ working
                      (Full Backup + Restore)
                      1.Boot with recovery.img on sdcard unplug power kabel and enable reset button and plug Power kabel back in.
                      2.Flash with Rashr app recovery.img an reboot With rebooter app
                      (Xposed) Gravitybox or a rebooter app from Playstore
                      Rashr:
                      https://play.google.com/store/apps/d....recoverytools
                      If you Backup Rom select Also recovery and by Restore Rom
                      Thanks for the TWRP 😀
                        Hello,
                        Just tried Rashr but when I click on Rashr I get this error: Error Setting Up Layout
                        Any idea how to get past this error
                        thanks again
                          Hi is there any chance some one could make a twrp recovery for my M8s s812 please.? I have the recovery.img file.
                          Thank You
                            Originally posted by stevemp View Post
                            If you are repairing then use Amlogic USB Burning Tool and find a recovery that has usb instead of sd in description.
                            I already tried it earlier, many times - unsuccessfully.
                            http://freaktab.com/forum/tv-player-...389#post534389
                              Hi Abdull , i am looking TWRP for my box (m8 amlogic s812), tried already k200,m8s+ , but it doesn't work.
                              which one i have to use?
                              stock recovery
                                stock recovery
                                I have the same model as you. Please Abdul could you create a TWRP for our box?
