TWRP for Amlogic devices.
    Hi abdul_pt ,
    Please help for TWRP recovery.
    Thanks!
    Originally posted by yhaddad View Post
    [USER="16264" ] abdul_pt [ /USER] ?
      abdul_pt - Any chance you could work your magic on the newly released FW for the X8-H Plus? Thanks in advance.
      Sent from my Nexus 6 using Tapatalk
        hi abdul_pt can twrp for the beelink mini mx back up more than just the data partition , can it back up the emmc storage which openelec installs on. also beelink have just released a new update to 104L for the box on ota update, will there be a new version for this? at the moment your twrp can only see bootloader partition but fails to back up only backs up 2 folders , system & data, all other folders are showing 0kb
          hello, i would like to know if the dtb file can be dumped (directly or indirectly) with twrp ? Or if you know another way to do that, adb, uboot, i have serial debug set up ? it's for a Beelink MXQ (red ribbon), i'm building some kernel images to run headless linux (debian, ubuntu, arh) on those boxes, i don't have much experience with arm boards. At the moment the stock android system is still on the nand and i run openelec from sd card. thx
            Hi
            i own a mbx m8s n200c 2gb ram 8gb which i bricked (original firmware was KOT49H.20151110)
            i followed these instructions apparently with wrong img for my box
            http://freaktab.com/forum/tv-player-...owners-warning
            the box boots with blue light but freezes at the beginning of mbox logo and i cannot enter recovery at all
            is there a way to install twrp recovery so that i can try to find a proper rom?
            http://freaktab.com/forum/tv-player-...865#post550865
              redshift Sorry i won't be able to help you much but i was wondering how you identified your box as being an n200c ?
                before bad flashing and bricking i downloaded various system info apps from store and all indentified it as
                MBX M8S N200C 2gb ram 8gb rom ,but they couldnt indentify the wifi module
                  Any news on twrp for mini mx abdul
                    Hi Abdul.. great work!!
                    So i have Mini MX S905 1gb/8gb box direct from beelink. I am able to boot into TWRP fine but it doesn't seem to want to do the back up.
                    looks like all is going well then it gives an error and stops the backup.
                    ** Also showing 0mb on sd card under storage
                    Any advice would be greatly appreciated.
                    Deezel
                    Three days of testing can save 10 minutes reading manuals
                      I am in the same boat as Deezel i am using a mini mx s905 1gb/8gb and want to tanfer my setup on my parents box ty
                        Deezel
                        I had this problem with the mini mx twrp, it does not read the partitions correctly and reads the external sd card as 0mb, you are using a genuine bee-link box same as myself, I think this twrp is for a clone box not original. I am 100% sure mine came from bee-link direct not through some retailer. hopefully Abdul will fix this soon ive sent him the partition table and the genuine firmware.
                          Whenyou saying genuine firmware do you mean 103L or 104L firmware. As lots of us are staying on 103L due to issues on 104L firmware
                            It was the same on 2l and 3l and Abdul has both versions, I've not updated to 4l.
                            So your twrp working on mini mx? Is it a genuine bee-link box or don't you know ?
                              Mine is genuine and no not working
                                Hello,
                                I have an MBX M8S+ AmLogic Android TV box, does someone know which TWRP recovery to use?
