TWRP for Amlogic devices.
Nvm, i fixed all my issues.
Can't get the images away.You may only view thumbnails in this gallery. This gallery has 2 photos.2 PhotosLast edited by Chaosstorm; 30 March 2016, 22:10.
Hi Abdul,
Have a MXiii box, 2 gB, seems to be an s802 with sandisk nand. On print it show mxiii v 3.1 from october 2015.
With this box recovery with toothpick is not possible, it stays in a loop with showing smart tv logo..
Anyone knows this box and what kind of TWRP and firmware I can flash, this one has google play services error when I power box on with lan cable connected.
Thanks,
Originally posted by Ostrich Egg View PostSorry for the noob question, but does anyone know if any of the s905 recoveries in the OP works with the MXQ Pro, this one http://www.cnx-software.com/2015/10/...t-hevc-videos/
If recovery needs to be built, I can (hopefully) provide whatever input is required.
Hello
I too have a s905, a JUSTOP T95 Amlogic S905 64bit chipset. Which TWRP do I use? I've searched for ages and can't find much mention of this model. Is it a clone of another device?
Thanks in advanceLast edited by AtariSoul; 01 April 2016, 21:28.
[ATTACH=CONFIG]n564126[/ATTACH]
Thanks,
Hi People I have read this thread twice and the information is mind boggling. I am trying to check if I have the right TWERP for my M8N the board is marked M8-M9 vers 1 2014-7-7 . The Twerp file I have downloaded is TWERP_2.8.7.0_M8N.img I have renamed the file recovery.img and loaded it to a SD card. When I power up the box using a toothpick it takes me to a page that has Boot into recovery highlighted is this right or do I have the wrong file. I am on a pension and cannot afford to replace this box if I brick it. your help wouldbe most appreciated.
Thanks,
If no available image works for you, then upload your stock recovery.img so that i can check it.
I too have the same problem with the new Matricom Q2. I tried all of the images for the S812 on page 1 and none of them work. All just bypass and boot as normal.
I have attached the recovery image that comes with the new box.
It appears to be an AMLOGIC Meson8. Meson chip version = RevA (1D:A - 0:74E). This is the memory map from last_kmsg: (I think this is the pertinent part you would need - if I remember correctly). I would do this myself but don't have the experience I'm afraid.
add_emmc_partition
[mmcblk1p01] bootloader offset 0x000000000000, size 0x000000400000
[mmcblk1p02] reserved offset 0x000002400000, size 0x000004000000
[mmcblk1p03] cache offset 0x000006c00000, size 0x000020000000
[mmcblk1p04] env offset 0x000027400000, size 0x000000800000
[mmcblk1p05] logo offset 0x000028400000, size 0x000002000000
[mmcblk1p06] recovery offset 0x00002ac00000, size 0x000002000000
[mmcblk1p07] misc offset 0x00002d400000, size 0x000002000000
[mmcblk1p08] boot offset 0x00002fc00000, size 0x000002000000
[mmcblk1p09] system offset 0x000032400000, size 0x000040000000
[mmcblk1p10] data offset 0x000072c00000, size 0x000331200000
Dropbox:
Recovery.img https://www.dropbox.com/s/zmvm0p2fnx...overy.img?dl=0
Last_kmsg https://www.dropbox.com/s/05wryrzsmw...last_kmsg?dl=0
Hoping you can help.
Let me know if you need any other info on the Q2 box.
There are currently 2074 users online. 1 members and 2073 guests.
