Thank you
TWRP for Amlogic devices.
Originally posted by scooter2014 View PostSERIOUSLY?? Lose the attitude first and that is your only warning. Abdul is one of the most helpful you will meet. I know for a fact hed respond. Better then me id just ignore you.
I was looking for a response from anyone, preferably a user with a MiniMX-1G or 2G.
Sorry but I was frustrated that no one would respond to my post for a couple days. Not trying to be an ungrateful ass.
Originally posted by iCanuck View Post
Okay awesome thank you for the response and all your work. I will post my results.
Thank you
Originally posted by abdul_pt View Post
If you have no success, them we can work on making an image for that device.
I tried putting TWRP_MiniMX.img onto sdcard and renamed recovery.img, inserted sdcard and did toothpick method. It just boots into normal recovery.
Do you need anything from me?
Hello iCanuck, I have a different S905 box(S95) Can the card be seen when you are in Android? If not, try the card in a USB card reader. Some cards I have just don't work well in the slot. If the card is seen but the toothpick still fails, try this. Or if you have a terminal emulator installed in Android, enter "reboot recovery".
Good luck.
Originally posted by RISCy Dude View PostHello iCanuck, I have a different S905 box(S95) Can the card be seen when you are in Android? If not, try the card in a USB card reader. Some cards I have just don't work well in the slot. If the card is seen but the toothpick still fails, try this. Or if you have a terminal emulator installed in Android, enter "reboot recovery".
Good luck.Last edited by iCanuck; 14 May 2016, 05:18.
You will have to extract recovery from device, or tell me how to unpack those image because i didn't had any success in doing it.
I tried to upload the recovery image file but it failed.
Files can be found here:
Store photos and docs online. Access them from any PC, Mac or phone. Create and work together on Word, Excel or PowerPoint documents.
Select the "010- ATV1900AC Factory Files" file for the 1900AC
Originally posted by iCanuck View PostThanks I know how to boot into recovery and how to use it, yes I can see the sdcard in recovery but shouldn't it boot TWRP?
Originally posted by jm se View Post
Please try this one - https://www.freak-tab.de/abdul_pt/am...ATV_1900AC.img
Abdul_pt, I was able to install the image using Rashr
On Android 5.02 TWRP looks normal and on the image i provided you, it fills 1/4 of the screen and is purple. Pictures are attached. I'll try other version numbers and send you feedback
Boot time is about one minute to start TWRP, system boot time is normal
First time I selected wipe cache and davlik, the task ran and the box hung when formatting cache using make_ext4fs. This took about five minutes before the box locked up. I pulled the power cord to restart the box and tried again and second time I was successful.
I was able to install xposed framework 21 and different modules without any issues
Other than the TWRP boot speed everything seems to work.
I will also try to backup and restore images and provide you feedback on that also.
Thanks very much for getting this to work. Next thing is a usable ROM
Update: Reinstall of TWRP fixed the 1/4 screen and purple image, also forcing the box to output 1080p/60 solved image alignment issue. TWRP now boots normally.
Performed a backup of everything and that was successful
When restoring the backup image, the box gets hung up making the system partition with the make_ext4fs command. If i restore system first I can go to main menu and restart restore and it completes successfullyAttached FilesLast edited by jm se; 18 May 2016, 04:21.
There are currently 2122 users online. 0 members and 2122 guests.
