TWRP for Amlogic devices.
Originally posted by johnny64 View PostWhich version of TWRP and Amlogic K1plus S2 T2, and where to get instructions on how to install and where?
Try instalation with Rashr (Google store). Make backup of stock recovery first.
I purchased leelbox m8s on my recent trip to US, from the amazon link below ?
It's m8s box with s812 CPU and Android 4.4. I wanted to know is there any way to determine the correct recovery twrp image which will work this box, as there are 3 m8s images in first post itself ? This is first time I would be flashing a TV box, have flashed many phones and routers in the past.
Originally posted by tuff350 View PostWhich version will work with "prahjister's frankenstein-firmware" ?
"JWhitebrook: You might want to just use this build for the A95X S905X.
I have tried it on my 2G+8G box, first from SDcard along with a dummy.zip file to select using the UPDATE&BACKUP app instead of the non existent reset switch. With TWRP running I did a backup of the original firmware then installed TWRP image in place of the stock recovery partition. Now can reboot to TWRP recovery using the RebootManager App"
I had this on my Nexbox A95 S905x (2gb/16gb) with ORG ROM and it worked. I have since successfully flashed Frankenstein and have yet to try it on my Frank installation. I plan to try it out once I get my new Frank how I want it but, I would think that it should work since it's made for S905x chipset.
**SkystreamX4 (S802)....M8S (S812)....Mini M8S (S905)....Nexbox A95x (S905x)
Originally posted by ladyjack View Post
Give this one a try: I found it on the www.modaco.com/forums. It was posted by JWhitebrook:
There are currently 1763 users online. 6 members and 1757 guests.
