TWRP for Amlogic devices.
    hello dear abdul_pt
    i have a nexbox a1 box and i decided to flash my box (great stupidity) with other firmware from the beelink gt1 which I read and saw it has better environment and better status bar!
    for my good luck while testing (earlier) i maked a nandroid backup from an nexbox a3 firmware with a your twrp!
    so after testing the beelink's rom i tried to come back first with the usb way and i had the first shock!!!!!!
    usb stoped working and from that moment i never get to work this flash method!
    BUT GOOD FOR ME i still could get in twrp recovery and restored the a3 backup rom!
    now everything works except the blue on light wich is native off now and when i close the box then the blue light on !!!!!!
    ofcourse and t the conection of usb to my pc (the worst scenario of all) !
    unfortunatly i can not flash my box with NO way!!!
    the sd card method not working and paradoxical neither the online update !
    maybe if i had update files in . zip i probably could flash them from the update app in the box!! who knows?
    i also tried to flash an .img with this twrp(here i'll need your help) and i keep taking the 2 same errors : size of image is larger than target device AND :/sbin/postrecoveryboot.sh process ended with ERROR :17 (in photo)
    so ,is it possible to fix this to update and restore my nexbox a1 with this twrp you made for this box?
    update : a friend of mine helped me and i recover my box!
    thank you!
      Originally posted by trotter View Post
      su
      dd if=/dev/block/recovery of=/sdcard/recovery.img
      I gave it a go and it didn't work
        https://postimg.org/image/qhkqkcd9n/3dd344d9/
        Looks like the super user binarys are missing/need updating. The one that comes with a lot of these boxies is not the best.
        Your options would be to open the root app and it should then complain in some way that it needs updating, do what it asks of you.
        Or do what I did and go to the app store and install SuperSU,
        open that up and when it asks about binarys pick the option to install the binarys the normal way NOT the recovery way.
        After it has rebooted open it to make sure it's working.
        Then use a app that can uninstall system apps (I use titanium backup) to remove the root app that came with the unit.
        Then try to dump recovery again.
          Hello all,
          How can I do to compile TWRP for a Transpeed S905 2G/8G box?
            With this twrp for the gt1, I'll still get ota updates?
            Στάλθηκε από το Broken powered G2 D802 μου
              Hi, i have a mxIII android tv box it's it the stock rom bur sometimes overheats tends to have 90% or more use of the cpu after a shutdown stays on the normal condition.
              I need to make a backup of the stock rom and try other roms here the informations i have. I now that is dificult to put a rom on this but i need your help.
ID:	606642Click image for larger version
ID:	606643Click image for larger version
ID:	606644Click image for larger version
ID:	606645Click image for larger version
ID:	606646Click image for larger version
ID:	606647Click image for larger version
                I'm not sure where was the root app that came with it. I installed root king it did ask me to update binary. I update normal like u said too. I then installed titanium backup and then uninstall root king and I did the command in terminal and I got the same thing as the picture i post.
                  Hello, i'm trying to fix my mini m8s ii (s905x)tv box but i'm strugling.
                  I manged to get twrp on an sd card and have it boot.
                  Cant do anything else with it.
                  It looks like my internal storage is blocked or something.
                  Can anyone help me?
                    Hi Abdul.
                    I have a Tronsmart Mx3 plus, and can't find twrp anywhere . Can you help ?
                      I hope that's it. There's 2 files.
                      https://www.dropbox.com/s/79s0a3921n...chive.zip?dl=0
                      edit: now I need to figure how to get recovery img.
                      https://www.dropbox.com/s/a9dnn5u2mg...overy.img?dl=0 recovery img for mx2. got it from this site http://forums.cablecutters.com/matri...eshooting.html
                      hope to see twrp for mx2 soon.. thanks
                        For videostrong k1plus what version of twrp usable?
                        s905
                          please arrange for being able to switch between stock and custom recovery. ota may require stock
                            your recovery device partition might be slightly elsewhere, perhaps /dev/recovery or else search with
                            Code:
                            find /dev -name recovery
                              Code:
                              i believe that's it. I got from that site. Can make twrp for the mx2??
                                Hi Abdul_pt.,
                                Could I have Twrp for T95Z S912 please :-
                                Recovery -
                                ​​https://mega.nz/#!tVgm2YCK!euR84wczy...TjxOuM1SB1LYLg
                                block.txt ​​​​​
                                partitions.txt
