TWRP for Amlogic devices.
Originally posted by gatos814 View Post
Finally with this mod su everything worked fine !
now i can root and unroot the tv box and much fast i can say !
if i 'll find and other issues i'll let you know !
only one last question for now : if i want to install something else in .zip files will they have "partition install" directions, problems?
THANK YOU AGAIN AND AGAIN VERY VERY MUCH !!!
Originally posted by abdul_pt View Post
it works flawlessly
also started NAND and SD Card and USB
Originally posted by abdul_pt View PostDo you have a External SDcard inserted the Box ?
This is not my box (a friend's one). I may want to try once more over the weekend. But, again, for me it's OK that I could backup to USB stick.
Thanks for having built the MXQPro-4K p201 TWRP!
Hi abdul_pt,
I admire your work. Can you please send me a TWRP recovery for my box.
Everything you need is attached. http://dox.bg/files/dw?a=834963229b alternative link: http://www.filedropper.com/mxqpro4k
Thank you in advance.Last edited by adjiski; 06 October 2016, 19:02.
Originally posted by bjyjhn View PostMany thanks Abdul_pt for Beelink GT1 twrp recovery img. Do you have a mod for supersu.zip for GT1 ?
That's a TWRP made by me for a s805 device.
Does that recovery work for you ??
Ο λογος που σου απαντησα ετσι ειναι γιατι και εσυ παλιοτερα απαντησες με τον ιδιο τροπο σε αλλο παιδι σε ελληνικο φορουμ,ειδες ''ροδα ειναι και γυριζει''.
Translation in english: The reason that i have answer your question in that way is because you did the same thing in a greek forum to some other guy instead of helping him you suggested him to do some reading instead of asking questions. ''What goes around, comes around''
Originally posted by aeolous
Sometimes is a good thing to do some reading first, read the first post it will answer your question.
Πόσο μπετοβλακας και κακόψυχος είσαι.
Your attitude is offensive, if you don't want to help don't post, so simple
Στάλθηκε από το Turbo powered G2 D802 μου
There are currently 4245 users online. 0 members and 4245 guests.
