TWRP for Amlogic devices.
Hmm I couldnt get the mini_m8s_ii to work on my X96 Box, although the devices firmware does load onto mine, Could I please ask for TWRP for X96 Box's
EDIT : These guys seem to have a twrp for X96 but the file was deleted :/ http://4pda.ru/forum/index.php?showtopic=767468
EDIT 2 : I have found the file, I looks like 3.0.2.0 and can confirm that it works on the box pictured below. X96_1GB/8GB
The forum uploader keeps dying on my crappy upload speed so heres a fileshare link http://www83.zippyshare.com/v/W9kCMzjw/file.html
abdul_pt this link is a zip with blocks.txt, partitions.txt and recovery.img of my r-box pro 3gb ram
What recovery do i need?
Thnks so much for your workZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Thank you very muchZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
hi i have beelink gt1 wanting to flash Alfawise S92 Superceleron BETA v1 Rom , i have installed twrp have used before few times i have the image file he has avaible for download but the only options it is giving me to flash image is logo, recovery , boot not giving a system option how can i flash the image to system
Just registered to say thank you for build TWRP3_VegaS95_Meta which i can now confirm working on the Docooler M9S Pro Android 5.1 Amlogic S905.
I didn't see this in the list but after some googling, I found it and it worked like a charm. Also this version is reported to work on the MXQ Pro+ for those interested
Thanks again..
Hi abdul_pt, thank you for your hard work building the TWRP recovery images.
I have an MXQ Pro 4K S905 and I cannot seem to find the right TWRP recovery img
I have tried pretty much all the images on the first page of this thread, I have also tried these listed below and none of them work. What is needed to build a working recovery image ?
files I have tried...
recovery_twrp_p200_s905.img
TWRPMXQ-Pro-4K-p201.img
TWRP3_T8x.img
TWRP3_Mini_M8S.imgAttached Files
Hi!
i have a problem. I flashed twrp in my tv box. i had tried going into recovery mode with app quickboot but tv box stay in Splash screen and never went into recovery. After try it some times i push reset button with toothpick for few seconds and i got entry in twrp and i can flash xposed.
Well, today i want to make a back up but the same problem, i cant run recovery mode. Dont work quickboot and dont work toothpick, tv box is freezing in R-box pro logo
I've flashed again twrp but i cant go to recovery mode yet
I have screenshot of twrp manager. It say a have a twrp recovery installed
What can i di to go to recivery mode?? Thank you very muchLast edited by Unkash; 04 December 2016, 19:22.ZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
Originally posted by resansid View Post
Hi Abdul! Is there a TWRP available for R-Box Pro. Some members recommending we use the TWRP 3.0.2 for Beelink GT1 can be used for R-box too?
Is this correct? If so Where is it available for download.
Many Thanks for your contribution to the community.
Link: https://mega.nz/#!iwkU2TrJ!_MzaXtxTL...im-Y3zom-7BgJIZTE BLADE S6
R-BOX PRO 3GB RAM
M8S RK3288
@abdul_pt i have a t10 mini by tictid and i have tried every .img you posted in the op and second post if you could please compile for this i would really appreciate it i am attaching the required files now
https://www.dropbox.com/s/29dgiwob4y...files.zip?dl=0
Originally posted by qq3y6 View PostI have an MXQ Pro 4K S905 and I cannot seem to find the right TWRP recovery img
A friend has a MXQ Pro 4K S905 and TWRPMXQ-Pro-4K-p201.img works. But then, there are several MXQ Pro 4K S905 models...
Just curious:
how do you install twrp recovery image?
how do you boot into twrp recovery?
what fails working (assuming you can boot into twrp recovery)
There are currently 1740 users online. 1 members and 1739 guests.
