TWRP for Amlogic devices.
Guest
Originally posted by rodrengo
sorry, i didn't read well....
Here are the files:
i can't acces to recovery anyway
sorry for the impatience
Originally posted by gatos814 View Posthello again abdul_pt
these are the files and i hope this time would be everything ok!
please check and the "choose storage"
thank you!!!
i was sure that everything works, the second time just fine, but when i was trying to install the latest su.zip (2.78), my tv box did the procedure and eveything seemed good untill the reboot
with this new su.zip(2.78)my tv box started very quick but nothing was installed in the apps!
with older su.zip(2.46), my tv box did again the procedure well but this time after the reboot i was in long boot loop !! (this happened 2 times)
good for me i found my stock rom and flash it to save my tv box!
now i'm thinking the problem maybe is, that it "writes" everything in wrong directions
something like that i think ,was happening at the begining and i could not find the TWRP backup file in my tv box !!!
so i sended this time my stock rom with the 2 txt files hoping you do your 'MAGIC" and this time i have a fully working recovery !!!
thank you again and waiting.......
Originally posted by abdul_pt View PostPlease report back
http://www.freak-tab.de/abdul_pt/aml...ro-4K-p201.img
update
Great: it works!
FYI: I reboot into recovery via Link2SD in Android.
minor comments
First time I tried I had not only an external SD card but also an USB stick connected, and mouse did not work (even when taken out/reinserted).
Then I removed USB stick and next time mouse did work. I could not select external SD as backup location. I reinserted USB stick and could select it.
Maybe next time will be different (I may want to take out/reinsert external SD card).
But what counts: it works!
you are a heroLast edited by Nofan Tasi; 03 October 2016, 18:25.
Originally posted by abdul_pt View PostGuys don't just ask for a TWRP for your device, you need to provide some things also.
Code:From PC do : adb root ( if ADB isn't root) adb shell cat /proc/partitions > partitions.txt adb shell ls -l -R /dev/block > block.txt Now where you open the terminal window are two txt files sent them to me and stock recovery From Terminal Emulator do : su cat /proc/partitions > /sdcard/partitions.txt ls -l -R /dev/block > /sdcard/block.txt Now on your internal SDcard are two txt files send them to me and stock recovery
Can I have a TWRP Beelink GT1 (S912)
files needed => http://www.mediafire.com/file/6z9hed...Partitions.zip
Thanks!
it seems that i rushed to get conclusions!
http://www.mediafire.com/file/j7yzac...itions.txt.zip
If you want to try this zip to root, it's a slightly modified SuperSU 2.78 - http://expirebox.com/download/fbc4b2...42366df3b.html
Originally posted by rodrengo View Post
Abdul don't forget me, please
sorry for the impatienceOriginally posted by DroiDMester View Post
Thanks!
Originally posted by Nofan Tasi View Post
Thanks, will do now!
update
Great: it works!
minor comments
you are a hero
Without a recovery image i can't do anything for you
SuperSU zip doesn't work on your box and that is a problem not related with the TWRP itself. The zip(SuperSU 2.78) simple doesn't find the boot partition and so it doesn't do anything. Read the output of the flash. Post recovery log of the zip flashing
if i got it rightly the twrp is working well and the problem is su , right ?
now , i don't understand which log you want, the one from the su 2.78 which is not working or i'll try this one the 2.78 mod and see what's will happen (recovery.log) ?
thank you!
edit : if you mean the 2.78 wich not working here is the recovery.log after the flash:Attached Files
Originally posted by abdul_pt View PostProvide recovery log
Note a few
Code:I:Unable to mount '/external_sd'
Code:I:Backup folder set to '/usb-otg/TWRP/BACKUPS/Amlogic'
Guest
Now, how can i do a recovery image? i tried with flashity, flashfire, rom manager and rom tools and i couldn't (doesn't recognize the recovery)
really thanks for help us!!!!
Thanks for your answer
Finally with this mod su everything worked fine !
now i can root and unroot the tv box and much fast i can say !
if i 'll find and other issues i'll let you know !
only one last question for now : if i want to install something else in .zip files will they have "partition install" directions, problems?
THANK YOU AGAIN AND AGAIN VERY VERY MUCH !!!
Beelink GT1 103M0 recovery => http://www.mediafire.com/file/76tqe5...1_recovery.zip
There are currently 2060 users online. 1 members and 2059 guests.
