TWRP for Amlogic devices.
Originally posted by Mywaruk View PostLinks to downloads are down, just a heads up if you wasn't aware.
Coincidence?! Who knows?!
@abdul_pt
What can I provide you with so that you might port a version for the M82 (1G/8G) MXIII?
Originally posted by Mywaruk View PostJust installed on my MX3 4K 2GB/8GB..
Installed great thanks! Backed up my device, formatted and reinstalled and all good!
Installed 1080p theme and works a treat thanks.
Thank you very much
Originally posted by mrgee View PostHi could you help a newbie out with same box on how to install and access twrp pleaseLast edited by Mywaruk; 26 January 2015, 13:05.
Originally posted by Mywaruk View PostDownload the correct twrp for your firware, i use 109k4 as im on 112k4, boot from sd to make sure it works (unzip twrp, drag the image file too root of sd) power off box and unplug, plug in with and place somthing in AV socket to push pin, powerup and you should be in twrp, if it works and want to flash it, place the zip file you downloaded on the sd card also and install it whilst in twrp recovery
Abdul,
Can you post the source code please?
Thanks!
Originally posted by abdul_pt View Post
Team Win Recovery Project 2.7, or twrp2 for short, is a custom recovery built with ease of use and customization in mind. We started from the ground up by taking AOSP recovery and loading it with the standard recovery options, then added a lot of our own features. It’s a fully touch driven user interface – no more volume rocker or power buttons to mash. The GUI is also fully XML driven and completely theme-able. You can change just about every aspect of the look and feel.
What's new in 2.8.1.0:
- MTP fixes and improvements - you can now copy zips to the root of storage - thanks to _that
- TrueType Font support - optional as it takes up a decent amount of space so may not be available on all devices - thanks to Tassadar
- Temperature support - thanks to bigbiff
- Various other bugfixes and tweaks
What's new in 2.8.0.1:
- Fix a bug that caused weird graphics and touch issues
What's new in 2.8.0.0:
- Add MTP support to recovery thanks mostly to bigbiff with a little help from Dees_Troy
- Add command line capabilities - you can now execute various TWRP features via adb instead of the touchscreen
- Add support for color in the console and give error, warning, and highlight lines different colors
- Track backup and restore progress based on file sizes to provide a much more accurate indication of progress
- Improve handling of /misc thanks to mdmower
- Improve setting of time on Qualcomm devices thanks to [NUT]
- Allow using images on slidervalue GUI objects thanks to Tassadar
- Allow using variables and addition and subtraction in variables for easier theming
- Add support for 1440x2560, 280x280, and 320x320 resolutions and update 240x240
- Allow ui.xml file to include additional xml files to help break up the theme and make TWRP easier to maintain
- Other minor fixes and improvements
You can know more about TWRP in here.
All credits should go to Dees Troy and all TeamWin members.
I just compile their sources.
The resolution is 1024x600, TWRP will be from top left corner to the rest of the screen, so it will look off center.
I have made 2 themes, one SD and one HD.
And now a smaller one 320x480
Themes:
The default resolution is 1024x600 witch might be a little small for some, so i made 2 flashable zip's with 2 new resolution's. Just flash this from TWRP.
Updated but still need feedback
- 1280 x 720
-1920 x 1080
To remove the theme, navigate to sdcard(data/media/0) and delete the theme folder inside the TWRP folder.
Install method:
- Copy the zip to your external SD or USB storage and flash it from stock recovery or TWRP.
- This images will also run from an external SD without the need to flash them, this is the adviced method to use.
Enjoy
TWRP Beelink s82b - not compatible with 109k4 onward
TWRP 2.8.1.0 Beelink s82b - 109k4
TWRP 2.8.1.0 EM8 - Stane's kernel
TWRP 2.8.1.0 Minix X8-H - Release 002
TWRP 2.8.1.0 Minix X8-H PLUS-
Stock recovery in flashable zip:
- Beelink S82b (108k4)
- Beelink S82b (109k4)
- Tomato M8 updated
- Minix X8-h beta9 r2
And if you like it so much to the point that you want to buy me a beer.
Newbie to TV boxes
Hi Guys, I'm a bit familiar with TWRP on phones, I have a few questions for the M8 square box version.
I have an M8N and a K200 (both M8 square boxes), would I use the TWRP 2.8.1.0 EM8 - Stane's kernel?
I was wondering, can I use TWRP to make a full backup of the M8N then restore that on the K200 or would that kill the K200?
Originally posted by Ichijoe View PostIf you read the top of the Board. You'd may note that this Sites FTP is currently down.
@abdul_pt
Originally posted by thekider View PostHi Guys, I'm a bit familiar with TWRP on phones, I have a few questions for the M8 square box version.
Probably
Here is the firmware
Originally posted by abdul_pt View PostA link to your FW would sufice.
Originally posted by yhaddad View Post
Do you have a slower link ???
There are currently 2590 users online. 2 members and 2588 guests.
