Re-uploaded the mibox2 boot.img and recovery.img
TWRP for Amlogic devices.
Originally posted by litan1106 View PostRe-uploaded the mibox2 boot.img and recovery.img
https://app.box.com/s/ml6v5rjebfy3o606wuvzc8im29f1gsgr
I don't know if that one was 'the right one' but it said MiBox2 on default.prop
Tapatalked
Originally posted by abdul_pt View Post
Originally posted by ZimbiX View PostBootloader loop on that one again, I'm afraid. Logs coming soonCode:ruby-2.1.2 in TWRP/ › tree . ├── TWRP_2.8.1.0_X8H_PLUS │ ├── Broken │ │ ├── last_log │ │ ├── minix-x8-h-plus-twrp-logs_TWRP_2.8.1.0_X8H_PLUS.zip │ │ └── partitions.log │ └── recovery.img ├── TWRP_2.8.5.0_X8_X8PLUS_X8H_003FW │ ├── Broken │ │ ├── last_log │ │ └── minix-x8-h-plus-twrp-logs_TWRP_2.8.5.0_X8_X8PLUS_X8H_003FW.zip │ └── recovery.img └── TWRP_2.8.5.0_X8_X8PLUS_X8H_003FW(2) ├── Broken │ ├── last_log │ └── minix-x8-h-plus-twrp-logs_TWRP_2.8.5.0_X8_X8PLUS_X8H_003FW(2).zip └── recovery.img 6 directories, 10 files
Tapatalked
I tried to use flash_image with su
0|root@dredd:/ # cat /proc/mtd
tmp-mksh: cat: /proc/mtd: No such file or directory
1|root@dredd:/ # chmod 755 /dev/flash_image
2|root@dredd:/ # /dev/flash_image recovery /data/recovery.img
error scanning partitions: No such file or directory
Please help, thanks.
I just confirm this image working OK on a X8-H, so i don't know what's happening.
Tapatalked
Originally posted by litan1106 View PostThanks, I got the mibox2 pro edition to flash the recovery.img with
dd if=/sdcard/recovery.img of=/dev/block/recovery
I noticed the "backup" don't work.
[ATTACH=CONFIG]10775[/ATTACH][ATTACH=CONFIG]10776[/ATTACH][ATTACH=CONFIG]10777[/ATTACH]
NO MOUSE PLEASE HELP!!!
Guys I flashed this and was not rooted before hand and now I cannot select a file from my SD card in recovery essentially permalocking my device. Any advice on how to root or fix? Since I dont have root I can't get to the root folder to find the "recovery.img"
Im begging for any help!! I'm trying ADB but not very familiar. ANy help is greatly appreciated!!
Originally posted by zmanfarlee View PostGuys I flashed this and was not rooted before hand and now I cannot select a file from my SD card in recovery essentially permalocking my device. Any advice on how to root or fix? Since I dont have root I can't get to the root folder to find the "recovery.img"
You should tell us about your device.
Im begging for any help!! I'm trying ADB but not very familiar. ANy help is greatly appreciated!!Originally posted by litan1106 View PostYou should backup the partitions before playing with it.
I wanted to do a bunch of stuff tonight but got caught on this for two hours. I am a newb that tries to dabble and getting it to work gives me a huge high. Thank you guys for this thread.
So yeah if this happens to you reset box and go forth and conquer.
Seiously thank you for responding I started freaking out then got it.
Originally posted by Dope101 View Postis there an amlogic MX version , i remember seeing it before think it was the sd card version?
Originally posted by litan1106 View PostCan you show me how to modify the twrp recovery.img please ? so I can fix the partitions.
Originally posted by abdul_pt View PostThey are standard android images. So split-bootimg.pl and gzip will do the trick, but i don't know if changing partitions mountpoints will make it backup.
There are currently 2294 users online. 2 members and 2292 guests.
