TWRP for Amlogic devices.
TWRP 2.8.1.0 Minix X8-H PLUS -
[/QUOTE]
Is this version also working with the latest X8-H PLUS ROM V2 update ?
Just curious if there are other MINIX 8+ owners here.
2.8.0.0 Works
Originally posted by abdul_pt View PostTry an older image for the m8. I have this on 'stock'
www.freak-tab.de/abdul_pt/aml/TWRP_2.8.0.0_m8.zip
www.freak-tab.de/abdul_pt/aml/TWRP_M8.zip
If none of those work, i will have to look better.
Thanks for the help!!!
-Iflyrctoo
minix X8-H PLUS
TWRP NOT fully functional
I reboot the system into Recovery from the App.
I only get the recovery menu:
-Reboot
-Apply update from ADB
-Apply update from EXT
-Apply update from cache
-Wipe data/factory reset
-Wipe cache
So no backup, no install with zip files, no TWRP in fact.
But it did add the menu at recovery boot which is more then before (I guess)
Any help appreciated and my box is available for testing.
TWRP for MiBOX2?
Originally posted by abdul_pt View PostIt might. Post a link to your FW.
Tapatalked
Another user has successfully made a bootable image from MicroSD for rooting the device:
Can you dig into the two images and find out necessary information? Xiaomi's devices all have two boot (boot and boot1) and system (system and system1) partitions. I can upload images if you need them. It will be fantastic if TWRP allows to select one of the two to install a custom rom. Many thanks!
Please help me. I flash wrong version of recovery (X8H PLUS instead of X8H). Now i can't boot into recovery (black screen), also root access doesn't work too. But device boot normally. How I can restore recovery? I can not do it with terminal (dd if=...) because i don't have root. I can't do it with zip-file (update) because i don't have recovery. I copy file recovery.img to sdcard and try to load in recovery mode. Nothing... (black screen again) What can I do?
Originally posted by xxrock View PostPlease help me. I flash wrong version of recovery (X8H PLUS instead of X8H). Now i can't boot into recovery (black screen), also root access doesn't work too. But device boot normally. How I can restore recovery? I can not do it with terminal (dd if=...) because i don't have root. I can't do it with zip-file (update) because i don't have recovery. I copy file recovery.img to sdcard and try to load in recovery mode. Nothing... (black screen again) What can I do?
Sadly in the case of the varies TWRPs on this Site. None of them seem to be compatible with my MXIII. I guessing I need to alter the fstab (File(s)), so as to get this working. Just how I go about doing that though? Is another question.
There are currently 4360 users online. 0 members and 4360 guests.
