You are using the External SD Card. And the recovery. IMG file ?
TWRP for Amlogic devices.
Edit: Just want to make sure you have stock recovery 09/17 installed. the twrp i'm using is the 2.7.1.0 version. It does install fine when i flash it but prefer to have stock recovery flashed and twrp as a backup
How to delete TWRP theme?
How to delete a theme?
Post 1 says "To remove the theme, navigate to sdcard(data/media/0) and delete the theme folder inside the TWRP folder."
Cannot delete this file or change permissions?
Have change to 1920 theme & now I cannot navigate TWRP to do anything??
Please advise if fixable, otherwise I guess a factory reset will sort it?Last edited by jellywobbles; 23 September 2014, 10:37.Live as if you were to die tomorrow. Learn as if you were to live forever
Originally posted by abdul_pt View PostWith any file manager you can delete that folder.
Never seen that, maybe a one time event. Definitely a strange thing.
Tapatalked
This S82B is working 100% OK - with a fully loaded XBMC.Last edited by jellywobbles; 23 September 2014, 15:30.Live as if you were to die tomorrow. Learn as if you were to live forever
Re: TWRP for Amlogic devices.
Tapatalked
Originally posted by abdul_pt View PostTapatalked
Does not work - unsifficient permissions !Live as if you were to die tomorrow. Learn as if you were to live forever
It does work, and that is a problem that you should put to the developer of the ROM you are using.
Why can't you delete a folder from the SDcard ?
Any how boot to recovery and with the file manager delete the folder.
Connect the box to the PC, mount storage and delete the folder.
Open terminal window and delete the folder.
Did you use any of this options ?
Tapatalked
Originally posted by abdul_pt View PostIt does work, and that is a problem that you should put to the developer of the ROM you are using.
Tapatalked
Thanks for your helpLive as if you were to die tomorrow. Learn as if you were to live forever
There are currently 2529 users online. 0 members and 2529 guests.
