Copied TWRP.zip to SD card (64g) used a 1 gig card previous, it complained
Installed TWRP.zip from Update&Backup
All Apps, Power, Reboot Recovery.
TWRP loaded
Top left had corner of screen, I use 1080p. very readable not a problem.
Had a look around interface looks good and not hard to use
Gave the backup a name. (shorter)
Did not delete any files.
selected Backup to external sd card.
My KR400 logitech mouse detected fine just dam tricky to swipe to get it
started a click would be great.
124 seconds to back up only have a small amount of apps on at present.
Uninstalled some apps to ensure backup was legit.
All apps, Power, Reboot recovery
TWRP loaded
Selected Restore.
118 seconds to restore from ext SD card
Reboot
All apps I unistalled are Back and all working well as I type
Settings for Digitally Imported and Static DNS did not hold need to re-entered.
Well Done
.gif)
