I'm have no problem with it.
TWRP for Amlogic devices.
Great!!!!
Originally posted by oman View PostAnd if it works fine,Could I put it into stock FW,abdul?
sorry to be a buzz kill, but I'm guessing you won't want any legal issues arising from using their project in a commercial sense.
Originally posted by saor11 View PostI installed this on finless 1.8 then installed zip for 720 p and its after messing up the screen the status bar is after been clipped so all sides
Didn't understand what you meant.
I tested the 720p zip on 108k4 without any issues, didn't test the 1080p though.
I have finless 1.8 running on my box with his 720p patch. When I installed your twrp zip and rebooted the image on screen has now been reduced in size its not off centred its like its been cropped you can't see the status bar anymore and the bottom of the icons on the bottom of the screen are also gone.
Originally posted by gizmomelb View Postas much as I would love this to be in the stock Beelink firmware, you may need to also obtain permission from the original developers - http://www.teamw.in/project/twrp2
sorry to be a buzz kill, but I'm guessing you won't want any legal issues arising from using their project in a commercial sense.Easy way to catch LOG -> Search 'Syslog' in Google Play,then install it and catch log
Originally posted by oman View PostWow,well done...
But I cant install it,Or I dont know how to install it rightly..
I download the twrp_s82b.zip,and put it into USB HDD,and run the stock recovery,then select 'apply update from EXT->Update from udisk->select the twrp_s82b.zip',but it failed ,showing:
Code:set_perm:some changes failed E:Error in /tmp/sideload/package.zip (Status 7) Installation aborted
same problem like Oman with S82B 2.1 Rom 108K4 and then stuck in TWRP, can`t reboot to android.
Greets
There are currently 865 users online. 0 members and 865 guests.
