TWRP for Amlogic devices.
    I can't download it
      Download link no good!
      Download link is down:-
      Not Found
      The requested URL /abdul_pt/aml/twrp_s82b.zip was not found on this server.
      Can you please upload again?
      Live as if you were to die tomorrow. Learn as if you were to live forever
        We're with some ftp problems, be patience.
        Note:  This blog post outlines upcoming changes to Google Currents for Workspace users. For information on the previous deprecation of Googl...
        Tapatalked
        if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
        then mv $user.contact.up.post /.trash; set response($response.type = ignore);
        $user.up.post.ignore_in_future = true; fi;
          Tapatalked
          Thanks abdul
            Until we have the FTP problem solved here's a mirror
            TWRP s82b
              Need some volunteers for testing...
              TWRP Acemax m8
              TWRP x8-h
              Install like stated on the OP.
              If something isn't working right, please provide if possible, recovery.log and dmesg. You can go to advance tab, and choose copy log to SD or do adb pull tmp/recovery.log
                Would really appreciate if you could release TWRP for the M8 square box! This will make my config complete
                Thanks a lot!
                  Can you point me to a FW ?
                  I thought that the acemax m8 was the M8 square.
                  Tapatalked
                    Tapatalked
                    It is.
                    Bob's 1.8 rom below is based on acemax july release but much better:
                    I'll test the TWRP_m8.zip with 1.8 on my square m8 & restore a nandroid when I get back home later tonight.
                      TWRP x8-h
                      - Flashed with recovery of 002Beta6 (KOT 49H.20140717).
                      - Script runs till 'script succeeded: result was [0.100000]' and stops there (went not back to recovery menu).
                      - Restart by off/on -> reboot to recovery (via UPDATE&BACKUP APP) ->
                      At [Restore] I can select External SD but see no folders or files?
                      (My first time I use your recovery, so maybe normal )
                      [Reboot] -> [Power Off ] ->
                      Copy Log didn't work (find no file at SD) but find the following:
                      Code:
                      E: Find_File: Error opening 'sys/class/leds/lcd-backlight'
                      E: Unable to find partition size for '/logo'
                      E: Unable to find partition size for '/recovery'
                      E: Unable to find partition size for '/boot'
                      Updating partition details...
                      Full SELinux support present.
                      Copied recovery log to /data/media/0.
                      EDIT:
                      BTW 1080P will be nice
                      RK3288 Devices
                      - Overview BOX (LINK !)
                        TWRP Acemax m8
                        Testing on Square M8 s802 (not clone, current 0.92 PCB)
                        Bob's ROM Finless 1.8
                        Went into recovery via reset button
                        wiped cache
                        flashed TWRP_m8.zip
                        install succeeded [0.100000]
                        rebooted
                        went into recovery via 3 different apps 3 times
                        no success: old stock Recovery, 3e, persists:
                        Android system recovery <3e>
                        KOT49H 20140616 test-keys
                        No TWRP!
                        Also went into recovery via app
                        didn't wipe cache
                        flashed TWRP_m8.zip
                        No success again!
                        Maybe factory reset + flashing TWRP_m8.zip works
                        but I didn't try as didn't want to lose my data.
                        I don't think that might do it but there's a chance it might.
                        Someone who has just flashed 1.8, please try:
                        factory reset
                        flash TWRP_m8.zip
                        See if TWRP appears.
                        Most people here have flashed Bob's 1.8
                        I suggest Abdul and Bob jointly investigate why on M8 the old 3e recovery is persistent.
                        Thanks.
                          OK, found the bug:
                          Deleted recovery.img in root of internal memory
                          TWRP loads
                          wireless mouse works
                          Next step: making a nandroid backup & then
                          restoring that
                          wish me luck.
                          my last_log file:
                          __bionic_open_tzdata: couldn't find any tzdata when looking for Asia/Shanghai!
                          __bionic_open_tzdata: couldn't find any tzdata when looking for GMT!
                          __bionic_open_tzdata: couldn't find any tzdata when looking for posixrules!
                          Starting recovery on Sun Aug 3 01:47:07 2014
                          recovery filesystem table
                          0 /bootloader mtd bootloader 0
                          1 /logo mtd logo 0
                          2 /aml_logo mtd aml_logo 0
                          3 /recovery mtd recovery 0
                          4 /boot mtd boot 0
                          5 /system ext4 /dev/block/system 0
                          6 /cache ext4 /dev/block/cache 0
                          7 /data ext4 /dev/block/data 0
                          8 /sdcard vfat /dev/block/mmcblk0p1 0
                          9 /udisk auto /dev/block/sda1# 0
                          10 /tmp ramdisk ramdisk 0
                          mtd partition 0, bootloader
                          mtd partition 1, ubootenv
                          env device is /dev/mtd/mtd1 erasesize=(0x01000) envsize=(0x10000)
                          E:Bad bootloader arguments
                          "(null)"
                          W:try mount /dev/block/mmcblk0p1 ...
                          W:try mount /dev/block/sda11 ...
                          W:try mount /dev/block/sda12 ...
                          W:try mount /dev/block/sda13 ...
                          W:try mount /dev/block/sda14 ...
                          W:try mount /dev/block/sda1 ...
                          E:failed to mount /udisk (No such device)
                          E:cannot mount /udisk (No such device)
                          E:Can't mount /udisk/factory_update_param.aml
                          ---void factory_reset_wipe_data(int*, char***),wipe_data=(null)
                          locale is [en_US]
                          I:loaded /etc/recovery.kl
                          I:recovery key map table
                          I:=========================
                          I: 0 type:select value:-4 key:28 15 158 -1 -1 -1
                          I: 1 type:down value:-3 key:108 114 109 -1 -1 -1
                          I: 2 type:up value:-2 key:103 104 115 -1 -1 -1
                          I: 3 type:back_door value:-6 key:128 26 118 -1 -1 -1
                          I:
                          framebuffer: fd 6 (1920 x 1080)
                          installing_text: en (324 x 38 @ 411)
                          erasing_text: en (109 x 38 @ 312)
                          no_command_text: en (172 x 38 @ 312)
                          error_text: en (64 x 38 @ 312)
                          Command: "/sbin/recovery" "--show_text"
                          hw.has.bluetooth=false
                          hw.has.accelerometer=true
                          hw.nopm=true
                          hw.nogps=true
                          hw.cameras=0
                          hw.nophone=true
                          hw.nobattery=true
                          hw.novibrate=true
                          hw.hasethernet=true
                          hw.hasusbcamera=true
                          ro.hw.ethernet.onboard=true
                          ro.sf.hwrotation=0
                          ro.ui.cursor=surface
                          ro.adb.secure=1
                          ro.app.optimization=true
                          ro.com.android.dateformat=MM-dd-yyyy
                          ro.boot.firstboot=0
                          ro.osd2.size=64x64
                          ro.wifi.channels=11
                          ro.alarm.align=true
                          ro.allow.mock.location=0
                          ro.board.platform=meson8
                          ro.build.id=KOT49H
                          ro.build.date=Mon Jun 16 09:33:13 CST 2014
                          ro.build.date.utc=1402882393
                          ro.build.host=ubuntu188
                          ro.build.tags=test-keys
                          ro.build.type=user
                          ro.build.user=ubuntu
                          ro.build.display.id=KOT49H.20140616 test-keys
                          ro.build.product=k200
                          ro.build.version.sdk=19
                          ro.build.version.release=4.4.2
                          ro.build.version.codename=REL
                          ro.build.version.incremental=20140616
                          ro.build.description=k200-user 4.4.2 KOT49H 20140616 test-keys
                          ro.build.fingerprint=MBX/k200/k200:4.4.2/KOT49H/20140616:user/test-keys
                          ro.build.characteristics=mbx
                          ro.camera.exif.make=M6
                          ro.camera.exif.model=g18ref
                          ro.camera.preview.MaxSize=1280x720
                          ro.camera.preview.UseMJPEG=1
                          ro.camera.preview.LimitedRate=1280x720x30,640x480x 30,320x240x28
                          ro.config.low_ram=true
                          ro.config.ringtone=Ring_Synth_04.ogg
                          ro.config.alarm_alert=Alarm_Classic.ogg
                          ro.config.notification_sound=pixiedust.ogg
                          ro.screen.has.tvout=true
                          ro.screen.has.timeout=false
                          ro.screen.has.brightness=false
                          ro.secure=1
                          ro.amlogic.no.preloadclass=1
                          ro.carrier=unknown
                          ro.product.cpu.abi=armeabi-v7a
                          ro.product.cpu.abi2=armeabi
                          ro.product.name=k200
                          ro.product.board=k200
                          ro.product.brand=MBX
                          ro.product.model=K200
                          ro.product.device=k200
                          ro.product.locale.region=US
                          ro.product.locale.language=en
                          ro.product.manufacturer=MBX
                          ro.baseband=unknown
                          ro.bootmode=unknown
                          ro.ethernet.default_on=true
                          ro.hardware=amlogic
                          ro.opengles.version=131072
                          ro.platform.has.tts=false
                          ro.platform.has.pppoe=true
                          ro.platform.has.touch=false
                          ro.platform.has.cecmode=false
                          ro.platform.has.cvbsmode=false
                          ro.platform.has.security=false
                          ro.platform.has.mbxuimode=true
                          ro.platform.has.digitaudio=true
                          ro.platform.has.defaulttvfreq=false
                          ro.platform.has.realoutputmode=true
                          ro.platform.hdmionly=true
                          ro.revision=11
                          ro.serialno=12345678900
                          ro.ubootenv.varible.prefix=ubootenv.var
                          ro.firstboot=0
                          ro.quickboot.enable=false
                          ro.statusbar.button=false
                          ro.statusbar.widget=false
                          ro.statusbar.yearmonthdayweek=false
                          ro.bootloader=unknown
                          ro.debuggable=0
                          ro.factorytest=0
                          ro.permissions.settings=true
                          drm.service.enable=true
                          ds1.audio.effect.support=false
                          ds1.audio.multichannel.support=false
                          dtv.standard=DVBS
                          gps.enable=false
                          has.media.poll=true
                          mbx.timeout.enable=false
                          mbx.3D_Bright.enable=false
                          net.bt.name=Android
                          net.change=net.bt.name
                          sys.fb.bits=32
                          sys.screensaver.enable=true
                          sys.keeplauncher.landcape=true
                          sys.defaultStream.ismusic=true
                          hwui.render_dirty_regions=false
                          init.svc.console=running
                          init.svc.display=running
                          init.svc.healthd=running
                          init.svc.ueventd=running
                          init.svc.recovery=running
                          init.svc.remotecontrol=stopped
                          prop.sp.brightness=off
                          wifi.interface=wlan0
                          const.window.h=1080
                          const.window.w=1920
                          debug.hwui.render_dirty_regions=false
                          media.arm.audio.decoder=ape,flac,dts,ac3,eac3,wma, wmapro,mp3,aac,vorbis,raac,cook,amr,pcm,adpcm
                          media.wfd.use-pcm-audio=true
                          media.wfd.videoframerate=20
                          media.wfd.videoreolutiontype=0
                          media.wfd.videoreolutiongroup=5
                          media.decoder.vfm.defmap=decoder ppmgr deinterlace amvideo
                          media.amplayer.enable=true
                          media.amplayer.startmode=true
                          media.amplayer.thumbnail=true
                          media.amplayer.dsource4local=1
                          media.amplayer.enable-acodecs=ac3,eac3
                          media.amplayer.support-exname=divx,h264,avi,ts,m2ts,mkv,mp4,mpg,mpeg,rm,r mvb,wmv,ts,dat,vob,vc1
                          media.amplayer.widevineenable=true
                          media.amplayer.support-exname1=mp2,mp3,ac3
                          media.libplayer.seek.fwdsearch=1
                          media.libplayer.modules=vhls_mod,dash_mod
                          media.amsuperplayer.enable=true
                          media.amsuperplayer.defplayer=PV_PLAYER
                          media.amsuperplayer.m4aplayer=STAGEFRIGHT_PLAYER
                          media.html5videowin.enable=1
                          config.enable_quickboot=true
                          dalvik.vm.heapsize=384m
                          dalvik.vm.heapmaxfree=8m
                          dalvik.vm.heapminfree=512k
                          dalvik.vm.heapstartsize=8m
                          dalvik.vm.heapgrowthlimit=64m
                          dalvik.vm.stack-trace-file=/data/anr/traces.txt
                          dalvik.vm.heaptargetutilization=0.75
                          gadget.nand.force_sync=true
                          persist.sys.usb.config=mtp
                          persist.sys.dalvik.vm.lib=libdvm.so
                          persist.sys.timezone=Asia/Shanghai
                          persist.sys.hideStatusBar=true
                          service.adb.tcp.port=5555
                          service.bootvideo=0
                          keyguard.no_require_sim=1
                          ubootenv.var.has.accelerometer=false
                          ubootenv.var.disp.fromleft=
                          ubootenv.var.bootcmd=run storeboot
                          ubootenv.var.cvbsmode=576cvbs
                          ubootenv.var.hdmimode=1080p
                          ubootenv.var.cecconfig=
                          ubootenv.var.firstboot=0
                          ubootenv.var.4k2k24hz_x=
                          ubootenv.var.4k2k24hz_y=
                          ubootenv.var.4k2k25hz_x=
                          ubootenv.var.4k2k25hz_y=
                          ubootenv.var.4k2k30hz_x=
                          ubootenv.var.4k2k30hz_y=
                          ubootenv.var.outputmode=1080p
                          ubootenv.var.480ioutputx=
                          ubootenv.var.480ioutputy=
                          ubootenv.var.480poutputx=
                          ubootenv.var.480poutputy=
                          ubootenv.var.4k2ksmpte_x=
                          ubootenv.var.4k2ksmpte_y=
                          ubootenv.var.576ioutputx=
                          ubootenv.var.576ioutputy=
                          ubootenv.var.576poutputx=
                          ubootenv.var.576poutputy=
                          ubootenv.var.720poutputx=
                          ubootenv.var.720poutputy=
                          ubootenv.var.1080ioutputx=
                          ubootenv.var.1080ioutputy=
                          ubootenv.var.1080poutputx=
                          ubootenv.var.1080poutputy=
                          ubootenv.var.4k2k24hz_width=
                          ubootenv.var.4k2k25hz_width=
                          ubootenv.var.4k2k30hz_width=
                          ubootenv.var.480ioutputwidth=
                          ubootenv.var.480poutputwidth=
                          ubootenv.var.4k2k24hz_height=
                          ubootenv.var.4k2k25hz_height=
                          ubootenv.var.4k2k30hz_height=
                          ubootenv.var.4k2ksmpte_width=
                          ubootenv.var.576ioutputwidth=
                          ubootenv.var.576poutputwidth=
                          ubootenv.var.720poutputwidth=
                          ubootenv.var.1080ioutputwidth=
                          ubootenv.var.1080poutputwidth=
                          ubootenv.var.480ioutputheight=
                          ubootenv.var.480poutputheight=
                          ubootenv.var.4k2ksmpte_height=
                          ubootenv.var.576ioutputheight=
                          ubootenv.var.576poutputheight=
                          ubootenv.var.720poutputheight=
                          ubootenv.var.digitaudiooutput=
                          ubootenv.var.1080ioutputheight=
                          ubootenv.var.1080poutputheight=
                          ubootenv.var.defaulttvfrequency=
                          libplayer.netts.recalcpts=1
                          libplayer.netts.softdemux=1
                          virtualsd.enable=true
                          dongleLauncher.enable.Animation=false
                          I:Saving locale "en_US"
                          -- Install /sdcard ...
                          Finding update package...
                          I:Update location: /tmp/sideload/package.zip
                          Opening update package...
                          I:read key e=3 hash=20
                          I:1 key(s) loaded from /res/keys
                          Verifying update package...
                          I:comment is 1738 bytes; signature 1720 bytes from end
                          I:whole-file signature verified against key 0
                          I:verify_file returned 0
                          Installing update...
                          flash_write env successful,sync & fsync...
                          write_raw_image: partition named "recovery"
                          new nand driver
                          @@@here------------data len = 10586102
                          ------------data len = 10586102 pos = 0
                          successfully wrote data at 0
                          wrote recovery partition
                          TWRP for Tomato m8
                          about to run program [/sbin/sh] with 3 args
                          + applypatch -c MTD:recovery:9521956:48b1154672fd30f1133e8337d2efe 48180362bd1
                          contents of partition "recovery" didn't match MTD:recovery:9521956:48b1154672fd30f1133e8337d2efe 48180362bd1
                          file "MTD:recovery:9521956:48b1154672fd30f1133e8337d2ef e48180362bd1" doesn't have any of expected sha1 sums; checking cache
                          failed to stat "/cache/saved.file": No such file or directory
                          failed to load cache file
                          + log -t recovery Installing new recovery image
                          + applypatch -b /system/etc/recovery-resource.dat MTD:boot:9511411:74b3978c1f250a505ff7f5ff2c9c703a5 c6bb2af MTD:recovery 48b1154672fd30f1133e8337d2efe48180362bd1 9521956 74b3978c1f250a505ff7f5ff2c9c703a5c6bb2af:/system/recovery-from-boot.p
                          patch MTD:boot:9511411:74b3978c1f250a505ff7f5ff2c9c703a5 c6bb2af: LoadPartitionContents called with bad filename (MTD:recovery)
                          contents of partition "boot" didn't match MTD:boot:9511411:74b3978c1f250a505ff7f5ff2c9c703a5 c6bb2af
                          source file is bad; trying copy
                          failed to read copy file
                          run_program: child exited with status 1
                          Install from sdcard complete.
                            Testing TWRP on MINIX X8-h
                            Installed as per instructions. Had same problem script succeeded but did not go back to reboot screen, solved same way by removing recovery.img from root.
                            Tried backup TWRP could not read logo, recovery or boot all 0mb, backed up data and system successfully and wrote log file.
                            Did not try to restore.
                            Log file uploaded.
                              OK, report on: Abdul's TWRP port for Square M8 on Bob's ROM 1.8
                              (cont.d):
                              Backup
                              Made nandroid backup on internal:
                              shortened name
                              chose all sections: boot sys data...
                              size was about 2.2gb
                              Backup was successful
                              Location @: /SD-Card1 (internal memory)/TWRP
                              I used internal instead of physical external SD-Card for speed.
                              Restore
                              Restored from recovery
                              took a while, finished restoring
                              reboot button failed: screen froze!
                              switched off box
                              switched on box
                              reboot started
                              android updated only 6 apps (Bob's ROM apps)
                              went into initial setup of android
                              settings were remembered, clicked a couple of OK buttons
                              going into android took about a minute
                              All my apps were restored too
                              Notes:
                              my wallpaper (app: No wallpaper) was replaced with Bob's ROM
                              some apps (xiialive radio + few) lost their settings
                              most apps + Nova launcher settings were restored fine
                              tested a few videos and channels on 2 xbmc:
                              add-ons restored fine
                              streaming and working fine
                              It's 720p:
                              TWRP covered the top left quarter of my 1080p screen only:
                              My Bob's 1.8 ROM is set to 1080p
                              switching the TV hdmi input box to satellite and back to M8:
                              made it recognize 720 mode and filled the screen
                              720p is good: works for all users
                              Restore from SD-Card:
                              Copied TWRP (folder) backup from internal memory to physical SD-Card(2)
                              rebooted into recovery
                              chose external: top box gives options: internal external otg
                              currently restoring (similar speed)
                              ................... should be OK when it finishes.
                              Thanks Abdul.
                                Report on: Abdul's TWRP port for Square M8 on Bob's ROM 1.8
                                (cont.d):
                                Restore from SD-Card (cont.d):
                                * Reboot button
                                after Physical SD-Card restore does work, no freeze
                                * After SD-Card restore:
                                + No updating of apps
                                + No going into settings
                                + No loss of settings as in few apps
                                + System reboots exactly as nothing happened and as it was
                                Perfect Restore.
                                Conclusion: restore from physical SD-Card.
                                Thanks Abdul.
