TWRP for Amlogic devices.
i am new to tv boxes and i am using a crt tv so maybe i'm getting this wrong but i flashed the zip ( did not unrar ) got the green man telling me its upgrading box booted back up screen is exactly the same i see no sign of twrp ,and if i switch the box off and back on there is no recovery option just standby or power off everything is working fine just no twrp.I am using latest stock rom and very puzzled
cheers
Originally posted by trinidad View Posti am new to tv boxes and i am using a crt tv so maybe i'm getting this wrong but i flashed the zip ( did not unrar ) got the green man telling me its upgrading box booted back up screen is exactly the same i see no sign of twrp ,and if i switch the box off and back on there is no recovery option just standby or power off everything is working fine just no twrp.I am using latest stock rom and very puzzled
cheersMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by Gaili View PostI did that already, i think there is something wrong with the installation from usb ... i canĀ“t use the sdcard because it`s broken.
I updated the script, now it check's for install-recovery.sh, and bypass this step if it isn't there or isn't executable.
Originally posted by abdul_pt View PostFor now this is only for the Beelink s82b and similar devices, but it can be ported to other aml s802 devices.
I tested briefly this image, but it looked like everything was working OK. Waiting for your feedback.
I left out some partitions for backup, 2 of them i couldn't get them to show in TWRP.
The resolution is 1024x600, TWRP will be from top left corner to the rest of the screen, so it will look off center.
Not working:
- Stock remote, use a mouse. Next release it will be fixed.
Install method:
- Copy the zip to your external SD or USB storage and flash it from stock recovery.
I put a chmod command on the zip, if the destination file isn't present the installation will fail and you will be stuck in the logo image. Unzip this file to the SD/USB, power off the device, remove USB cable, press the reset hole and power the device up
rescue from SD - s82b
Enjoy
TWRP Beelink s82b
Themes:
The default resolution is 1024x600 witch might be a little small for some, so i made 2 flashable zip's with 2 new resolution's. Just flash this from TWRP.
- 1280 x 720
- 1920 x 1080
To remove the theme, navigate to sdcard(data/media/0) and delete the theme folder inside the TWRP folder.
For who wants to go back
Stock recovery flashable zipBasically it's really simple to cover all M8 boxes with this because nand layout is stored in bootloader.
Originally posted by oman View PostAnd if it works fine,Could I put it into stock FW,abdul?
- remote (of course)
- reading .aml files for commands
- adding features which are aml specific (read/write to ubootenv, efuse, add secondary update.zip...)
Interesting project, but takes extra work to be done, its not just compile and thats it if you want to do it right.
Re: NEW - TWRP for Beelink S82b / Tronsmart S89
Originally posted by clarkss12 View PostIf you download and install a rebooter app from the app store, you can boot to recovery menu. Then you will boot into TWRP.REMEMBER, YOUR FEEDBACK IS VERY IMPORTANT TO US.My devices:
Originally posted by leolas View PostHere un this forum Petrus has an apk that can reboot to recovery, bootloader, power off por make a soft reboot. Give it a try.
Error (509)
This account's public links are generating too much traffic and have been temporarily disabled!
Originally posted by trinidad View Postseems very popular
Error (509)
I "only" have 1.2.2 but here is a mirror
RK3288 Devices
- Overview BOX (LINK !)
Guest
Excellent news, thanks Abdul.
Has anyone backed up a nandroid on the square M8 AND restored to check?
Originally posted by no_spam_for_me View Posthttp://www.freaktab.com/showthread.php?1050-Reboot-App
http://www.file-upload.net/download-...1.2.2.apk.html
nice one
Guest
Please abdul_pt make 2 themed 1920 & 720 new specific packaged versions for Square M8 as it has thousands of users and growing.
Thanks very much.
There are currently 855 users online. 0 members and 855 guests.
