TWRP for Amlogic devices.
    Originally posted by jm se View Post
    Abdul_pt, on behalf of the unfortunate people who bought this device, thank you for your efforts as they are very much appreciated.
    If their support is as good as their download speed....
    ETA of the download is tomorrow. 8-11 hours download time
    if [ $up.post.type = $type.two.lazy.to_use_google ] || [ $up.post.type = $type.silly_question ];
    then mv $user.contact.up.post /.trash; set response($response.type = ignore);
    $user.up.post.ignore_in_future = true; fi;
      Hi Abdul. Which one among the list in OP is for Mini M8S? Thanks!
        Here is a link for the IMG file from Mega
        Here is an alternative version of the file but zipped, from MyGica
        My bet is with Mega
          What's the difference between TWRP_M8S.img and TWRP_M8S_rev.img ?
          Thanks.
            I am happy to report that I was able to perform nandroid backup with data and restore successfully using the TW3_KIII_.img! I have also flashed it to replace the factory recovery. So far it works beautifully!
            Next step I will try wiping and flashing a factory firmware file. Do I need to flash the ota (.zip) file or do I need the factory image file (.img) to flash with TWRP?
            Thanks again, abdul_pt!
              Hi, tnx inadvance :-) I have OTT Bot M8S+ with S812 amlogic, 5.1.1 android, what is recovery option for my box ? tnx again
                Hi Abdul_pt, is there a mini m8s(s905) version available? Or can I use one from a different device?
                Sent from my MotoG3 using Tapatalk
                  Is there one that works with the mxq pro 4k?
                    I am trying the TWRP GS9 image on the Vega S95. Just running from SD card, I have not attempted an install.
                    Basics seems to run well, have not tried backup/restore yet. I will post back if successful.
                      I need the usual things to work on it .... if none works....
                        My bet is with Mega
                        You will have to extract recovery from device, or tell me how to unpack those image because i didn't had any success in doing it.
                          Thanks.
                          They have reversed mount points, in case of when using from ExternalSD or nand requires different mount points.
                            Great, by looking at the log you can see if there's any errors.
                              TWRP_MX64.img seems to work. Backup works but haven't tried restore. Is there a TWRP 3.0.2 version for Mini M8S? The usual things are in https://www.dropbox.com/sh/ws2kuq1lq...hpbaOsDGa?dl=0
                                Hello, I have very little experience using TWRP.
                                I am trying this on a Vega S95 Meta(S905). I ended up trying this image(from SD, did not install), http://www.freak-tab.de/abdul_pt/aml..._U1_SDcard.img.
                                Backups run and complete, I have not attempted a restore due to not being sure of the results....also known as fear.
                                I have attached a zip file with, the recovery logs(before and after backup) from the U1 image, the output from the commands and the F/W links.
                                If you have the time, please have a look.
                                Thanks either way.
