TWRP for Amlogic devices.
abdul_pt. Please help: I am a noob and I have a KIII Amlogic S905 TV BOX 2G/16G. The TWRP 2.8.7.0 Minix U1 was able to run from uSD card, but it fails to backup the nandroid. Does this mean that it is not compatible with the KIII? I am afraid to replace the stock recovery until I know it is the right one. Could you look at this image for the KIII S905 2GB 16GB posted on Acemax's Product SW download page: http://www.acemax.net.cn/downloading...center-14.html
Being a new member I don't know if I am allowed to attach links.
Many thanks for your great work!Last edited by Krakatau; 27 April 2016, 21:23.
Originally posted by abdul_pt View Post
Them try this one - https://www.freak-tab.de/abdul_pt/am...MXIII_v3.1.img
Same link, but different image.
Did you try this image ? And running from where ? External SD or nand ?
Originally posted by jm se View PostAbdul_pt, what information do you need to compile TWRP for MyGica 1900AC? Also please tell me how to get you the information.
Thanks in advance for your efforts.
Moved by post by abdul_pt
Sorry if this is OT for posting about KIII in this thread, but I hope I can help the cause for TWRP 3.0.2-x.
abdul_pt, before I try flashing it or restoring the backup could you look at the outputs of the /proc/partitions and /dev/block files and tell me if it's good to go?.
major minor #blocks name
253 0 512000 zram0
179 0 15646720 mmcblk0
179 1 15642624 mmcblk0p1
179 16 15267840 mmcblk1
179 17 4096 mmcblk1p1
179 18 65536 mmcblk1p2
179 19 524288 mmcblk1p3
179 20 8192 mmcblk1p4
179 21 32768 mmcblk1p5
179 22 32768 mmcblk1p6
179 23 8192 mmcblk1p7
179 24 8192 mmcblk1p8
179 25 32768 mmcblk1p9
179 26 32768 mmcblk1p10
179 27 524288 mmcblk1p11
179 28 32768 mmcblk1p12
179 29 1048576 mmcblk1p13
179 30 12781568 mmcblk1p14
179 64 4096 mmcblk1rpmb
179 48 4096 mmcblk1boot1
179 32 4096 mmcblk1boot0
8 0 30528032 sda
8 1 30528016 sda1
/dev/block:
brw------- root root 179, 28 2014-12-31 19:00 boot
brw------- root root 179, 17 2014-12-31 19:00 bootloader
brw------- root root 179, 19 2014-12-31 19:00 cache
brw------- root root 179, 25 2014-12-31 19:00 crypt
brw------- root root 179, 30 2014-12-31 19:00 data
brw------- root root 179, 20 2016-04-28 07:20 env
brw------- root root 179, 27 2014-12-31 19:00 instaboot
brw------- root root 179, 21 2014-12-31 19:00 logo
brw------- root root 7, 0 2014-12-31 19:00 loop0
brw------- root root 7, 1 2014-12-31 19:00 loop1
brw------- root root 7, 2 2014-12-31 19:00 loop2
brw------- root root 7, 3 2014-12-31 19:00 loop3
brw------- root root 7, 4 2014-12-31 19:00 loop4
brw------- root root 7, 5 2014-12-31 19:00 loop5
brw------- root root 7, 6 2014-12-31 19:00 loop6
brw------- root root 7, 7 2014-12-31 19:00 loop7
brw------- root root 179, 26 2014-12-31 19:00 misc
brw------- root root 179, 0 2014-12-31 19:00 mmcblk0
brw------- root root 179, 1 2014-12-31 19:00 mmcblk0p1
brw------- root root 179, 16 2014-12-31 19:00 mmcblk1
brw------- root root 179, 32 2014-12-31 19:00 mmcblk1boot0
brw------- root root 179, 48 2014-12-31 19:00 mmcblk1boot1
brw------- root root 179, 64 2014-12-31 19:00 mmcblk1rpmb
drwxr-xr-x root root 2016-04-27 22:07 platform
brw------- root root 179, 22 2014-12-31 19:00 recovery
brw------- root root 179, 18 2014-12-31 19:00 reserved
brw------- root root 179, 23 2014-12-31 19:00 rsv
brw------- root root 8, 0 2016-04-27 22:07 sda
brw------- root root 8, 1 2016-04-27 22:07 sda1
brw------- root root 179, 29 2014-12-31 19:00 system
brw------- root root 179, 24 2014-12-31 19:00 tee
drwx------ root root 2016-04-27 22:07 vold
brw------- root root 253, 0 2014-12-31 19:00 zram0
/dev/block/platform:
drwxr-xr-x root root 2014-12-31 19:00 d0072000.sd
drwxr-xr-x root root 2014-12-31 19:00 d0074000.emmc
drwxr-xr-x root root 2016-04-27 22:07 dwc2_b
/dev/block/platform/d0072000.sd:
drwxr-xr-x root root 2014-12-31 19:00 by-num
lrwxrwxrwx root root 2014-12-31 19:00 mmcblk0 -> /dev/block/mmcblk0
lrwxrwxrwx root root 2014-12-31 19:00 mmcblk0p1 -> /dev/block/mmcblk0p1
/dev/block/platform/d0072000.sd/by-num:
lrwxrwxrwx root root 2014-12-31 19:00 p1 -> /dev/block/mmcblk0p1
/dev/block/platform/d0074000.emmc:
lrwxrwxrwx root root 2014-12-31 19:00 boot -> /dev/block/boot
lrwxrwxrwx root root 2014-12-31 19:00 bootloader -> /dev/block/bootloader
lrwxrwxrwx root root 2014-12-31 19:00 cache -> /dev/block/cache
lrwxrwxrwx root root 2014-12-31 19:00 crypt -> /dev/block/crypt
lrwxrwxrwx root root 2014-12-31 19:00 data -> /dev/block/data
lrwxrwxrwx root root 2014-12-31 19:00 env -> /dev/block/env
lrwxrwxrwx root root 2014-12-31 19:00 instaboot -> /dev/block/instaboot
lrwxrwxrwx root root 2014-12-31 19:00 logo -> /dev/block/logo
lrwxrwxrwx root root 2014-12-31 19:00 misc -> /dev/block/misc
lrwxrwxrwx root root 2014-12-31 19:00 mmcblk1 -> /dev/block/mmcblk1
lrwxrwxrwx root root 2014-12-31 19:00 mmcblk1boot0 -> /dev/block/mmcblk1boot0
lrwxrwxrwx root root 2014-12-31 19:00 mmcblk1boot1 -> /dev/block/mmcblk1boot1
lrwxrwxrwx root root 2014-12-31 19:00 mmcblk1rpmb -> /dev/block/mmcblk1rpmb
lrwxrwxrwx root root 2014-12-31 19:00 recovery -> /dev/block/recovery
lrwxrwxrwx root root 2014-12-31 19:00 reserved -> /dev/block/reserved
lrwxrwxrwx root root 2014-12-31 19:00 rsv -> /dev/block/rsv
lrwxrwxrwx root root 2014-12-31 19:00 system -> /dev/block/system
lrwxrwxrwx root root 2014-12-31 19:00 tee -> /dev/block/tee
/dev/block/platform/d0074000.emmc/by-num:
lrwxrwxrwx root root 2014-12-31 19:00 p1 -> /dev/block/bootloader
lrwxrwxrwx root root 2014-12-31 19:00 p10 -> /dev/block/misc
lrwxrwxrwx root root 2014-12-31 19:00 p11 -> /dev/block/instaboot
lrwxrwxrwx root root 2014-12-31 19:00 p12 -> /dev/block/boot
lrwxrwxrwx root root 2014-12-31 19:00 p13 -> /dev/block/system
lrwxrwxrwx root root 2014-12-31 19:00 p14 -> /dev/block/data
lrwxrwxrwx root root 2014-12-31 19:00 p2 -> /dev/block/reserved
lrwxrwxrwx root root 2014-12-31 19:00 p3 -> /dev/block/cache
lrwxrwxrwx root root 2014-12-31 19:00 p4 -> /dev/block/env
lrwxrwxrwx root root 2014-12-31 19:00 p5 -> /dev/block/logo
lrwxrwxrwx root root 2014-12-31 19:00 p6 -> /dev/block/recovery
lrwxrwxrwx root root 2014-12-31 19:00 p7 -> /dev/block/rsv
lrwxrwxrwx root root 2014-12-31 19:00 p8 -> /dev/block/tee
lrwxrwxrwx root root 2014-12-31 19:00 p9 -> /dev/block/crypt
/dev/block/platform/dwc2_b:
drwxr-xr-x root root 2016-04-27 22:07 by-num
lrwxrwxrwx root root 2016-04-27 22:07 sda -> /dev/block/sda
lrwxrwxrwx root root 2016-04-27 22:07 sda1 -> /dev/block/sda1
/dev/block/platform/dwc2_b/by-num:
lrwxrwxrwx root root 2016-04-27 22:07 p1 -> /dev/block/sda1
/dev/block/vold:
Thank you.Last edited by abdul_pt; 02 May 2016, 01:45.
I tried the MXIII_v3.1 and all i get is black screen.
board: MXQ v3_1 20151230
Moved post by abdul_pt
Tonight I also tried the TWRP 3.0.2-0 on a Mini M8S. It boots from the external SDcard and I was able to do a nandroid backup with data to the external SDcard. Abdul, can you have a look at the partitions and /dev/block output files and the factory image from here?: https://www.dropbox.com/sh/ws2kuq1lq...hpbaOsDGa?dl=0.
Sorry, I think the firmware file is corrupt. Please wait while I try to find another one.
The firmware can now be downloaded from Queenslayer's OP: http://freaktab.com/forum/tv-player-...=1461992373135. Thanks to @Queenslayer!
The dropbox folder now contain both the update.zip and ota.zip as well as Mini M8S partitions and dev-block output files.Last edited by abdul_pt; 02 May 2016, 01:46.
Please provide stock FW image link, and the output of the commands 'cat /proc/partitions' and 'ls -l -R /dev/block'
Abdul_pt, on behalf of the unfortunate people who bought this device, thank you for your efforts as they are very much appreciated.
Here are links to the MyGica ATV 1900AC Firmware image
http://www.mygicasupport.com/viewtop...7b2ea1c6ca72d4
http://mygica.com/download/Software/...C_20160229.zip
# cat /proc/partitions
253 0 512000 zram0
179 0 15267840 mmcblk0
179 1 4096 mmcblk0p1
179 2 65536 mmcblk0p2
179 3 524288 mmcblk0p3
179 4 8192 mmcblk0p4
179 5 32768 mmcblk0p5
179 6 32768 mmcblk0p6
179 7 32768 mmcblk0p7
179 8 32768 mmcblk0p8
179 9 1048576 mmcblk0p9
179 10 524288 mmcblk0p10
179 11 12855296 mmcblk0p11
179 32 4096 mmcblk0boot1
179 16 4096 mmcblk0boot0
# ls -l -R /dev/block
/dev/block:
brw------- root root 179, 10 1969-12-31 19:00 backup
brw------- root root 179, 8 1969-12-31 19:00 boot
brw------- root root 179, 1 1969-12-31 19:00 bootloader
brw------- root root 179, 3 1969-12-31 19:00 cache
brw------- root root 179, 11 1969-12-31 19:00 data
brw------- root root 179, 4 2016-05-01 08:56 env
brw------- root root 179, 5 1969-12-31 19:00 logo
brw------- root root 7, 0 1969-12-31 19:00 loop0
brw------- root root 7, 1 1969-12-31 19:00 loop1
brw------- root root 7, 2 1969-12-31 19:00 loop2
brw------- root root 7, 3 1969-12-31 19:00 loop3
brw------- root root 7, 4 1969-12-31 19:00 loop4
brw------- root root 7, 5 1969-12-31 19:00 loop5
brw------- root root 7, 6 1969-12-31 19:00 loop6
brw------- root root 7, 7 1969-12-31 19:00 loop7
brw------- root root 179, 7 1969-12-31 19:00 misc
brw------- root root 179, 0 1969-12-31 19:00 mmcblk0
brw------- root root 179, 16 1969-12-31 19:00 mmcblk0boot0
brw------- root root 179, 32 1969-12-31 19:00 mmcblk0boot1
drwxr-xr-x root root 1969-12-31 19:00 platform
brw------- root root 179, 6 1969-12-31 19:00 recovery
brw------- root root 179, 2 1969-12-31 19:00 reserved
brw------- root root 179, 9 1969-12-31 19:00 system
drwxr-xr-x root root 2016-04-30 11:54 vold
brw------- root root 253, 0 1969-12-31 19:00 zram0
drwxr-xr-x root root 1969-12-31 19:00 aml_sdhc.0
/dev/block/platform/aml_sdhc.0:
lrwxrwxrwx root root 1969-12-31 19:00 backup -> /dev/block/backup
lrwxrwxrwx root root 1969-12-31 19:00 boot -> /dev/block/boot
lrwxrwxrwx root root 1969-12-31 19:00 bootloader -> /dev/block/bootloader
drwxr-xr-x root root 1969-12-31 19:00 by-num
lrwxrwxrwx root root 1969-12-31 19:00 cache -> /dev/block/cache
lrwxrwxrwx root root 1969-12-31 19:00 data -> /dev/block/data
lrwxrwxrwx root root 1969-12-31 19:00 env -> /dev/block/env
lrwxrwxrwx root root 1969-12-31 19:00 logo -> /dev/block/logo
lrwxrwxrwx root root 1969-12-31 19:00 misc -> /dev/block/misc
lrwxrwxrwx root root 1969-12-31 19:00 mmcblk0 -> /dev/block/mmcblk0
lrwxrwxrwx root root 1969-12-31 19:00 mmcblk0boot0 -> /dev/block/mmcblk0boot0
lrwxrwxrwx root root 1969-12-31 19:00 mmcblk0boot1 -> /dev/block/mmcblk0boot1
lrwxrwxrwx root root 1969-12-31 19:00 recovery -> /dev/block/recovery
lrwxrwxrwx root root 1969-12-31 19:00 reserved -> /dev/block/reserved
lrwxrwxrwx root root 1969-12-31 19:00 system -> /dev/block/system
/dev/block/platform/aml_sdhc.0/by-num:
lrwxrwxrwx root root 1969-12-31 19:00 p1 -> /dev/block/bootloader
lrwxrwxrwx root root 1969-12-31 19:00 p10 -> /dev/block/backup
lrwxrwxrwx root root 1969-12-31 19:00 p11 -> /dev/block/data
lrwxrwxrwx root root 1969-12-31 19:00 p2 -> /dev/block/reserved
lrwxrwxrwx root root 1969-12-31 19:00 p3 -> /dev/block/cache
lrwxrwxrwx root root 1969-12-31 19:00 p4 -> /dev/block/env
lrwxrwxrwx root root 1969-12-31 19:00 p5 -> /dev/block/logo
lrwxrwxrwx root root 1969-12-31 19:00 p6 -> /dev/block/recovery
lrwxrwxrwx root root 1969-12-31 19:00 p7 -> /dev/block/misc
lrwxrwxrwx root root 1969-12-31 19:00 p8 -> /dev/block/boot
lrwxrwxrwx root root 1969-12-31 19:00 p9 -> /dev/block/system
/dev/block/vold:
brw-r----- root root 8, 0 2016-04-30 11:54 8:0
brw-r----- root root 8, 1 2016-04-30 11:54 8:1
Originally posted by mega-samu View PostThe link of the minimx does not work.
Check OP, new links there
There are currently 2800 users online. 0 members and 2800 guests.
