TWRP for Amlogic devices.
[PROBLEM SOLVED]
After checking recovery logs, I've realized, that there was an old ".twrps" file and a "Theme" folder, located on sdcard.
TWRP loaded (some of) these files and this was, what caused the problems.
After renaming these files/folders, everything is fine.
Originally posted by abdul_pt View Post
Please try this one - http://www.freak-tab.de/abdul_pt/aml..._X8-H_Plus.img
Do you have an idea what could cause this behaviour?
So I can investigate for myself and compile and test TWRP.
I got confused with your post
Originally posted by marko33 View Post
Oh dear I must have deleted the wrong backup, was it your twrp? . Will it be bundled with the rom - I will have to find a download for it, think its the tronsmart one 102L1
Yes, it was TWRP
Yes it's working now, after deleting old TWRP files (Theme folder and .twrps) from Sdcard.ok
Originally posted by marko33 View Postok Abdul just tried the K200 version and now the external sd is visible, have just made a full backup to external sd. Anyone with MXIII-G s812 2gb 8gb Lollipop 5.1.1 factory firmware (unbranded MXIII Plus) needs to use this version
http://www.freak-tab.de/abdul_pt/aml..._K200_emmc.img
There are some many variations nowadays that i feel lost
ADB ?
From OP
Code:[B]Install method:[/B] - Download your image and rename to recovery.img - Copy the image to your External SD, and boot while pressing the reset button. On TWRP screen select install->images pick recovery.img [B]Alternative method[/B] - adb shell 'dd if=/path/to/recovery.img of=/dev/block/recovery ;sync;sync' [B]Issues:[/B] On booting to TWRP you might get a screen with stripes, or fill with one colour. Just wait around 3 seconds that TWRP curtain will show.
hi Abdul
I have not tried the adb method as I am not 100% sure on the process and didn't want to get my self in more of a mess than am already in..is the the only other method to make this work ?
like I say I had the original zip from your post that I used to just have on a sd card and in the android recovery I would install it via the install from ext. is this no longer possible seemed a very easy method ?
thanks for your time an reply
Originally posted by bluamber3131 View Post
hi Abdul
You can swap recovery.img inside the flashable zip and them flash it from the old TWRP.
I managed find my copy on old computer. I looked at file an it how you've just said. Anyway it works now so thanks for your help an reply. Thanks for your great work it's a life saver.
Cheers
There are currently 2220 users online. 0 members and 2220 guests.
