TWRP for Amlogic devices.
Try this ones- https://www.freak-tab.de/abdul_pt/am...8Plus_emmc.img
- https://www.freak-tab.de/abdul_pt/am...T8Plus_mtd.img
In case anything needs correction, report back with recovery.log and the output of 'cat proc/partitions' and 'ls -l -R dev/block'
Originally posted by borikua View Postabdul_pt
Thank you for your work.
You have listed TWRP 2.8.7.0 MXQ - Not verified
I understand that it is not verified but my question is if you are talking about MQX box with red & on/off button or the all Black MXQ or both?
I have all black MXQ and was hoping to try TWRP.
But testing for ExternalSD is pretty harmless.
Originally posted by abdul_pt View Post
I have no idea.
I did a backup in TWRP
I did a factory reset.
I did a restore in TWRP.
and the above worked for me.
I have an all black MXQ.
Original box remote does not work. I used a wireless mouse and that worked.
I went ahead and installed it and I have never really used this before but I believe it is working.
Hello!
I have installed Lollipop firmware on mine and have added a new remote.conf in order to have more buttons working with a Logitech Harmony remote.
But now, I would like to root the ROM by installing TWRP.
I have copied the recovery (TWRP 2.8.7.0 N200 emmc and TWRP 2.8.7.0 MXIII 1G) at the root level of a µSDcard and rename it 'recovery.img' and try to reboot the box but no chance to boot in TWRP :??:
Is something special to do to get working the recovery?
Even the command 'adb reboot recovery' is not working
Many thanks in advance!
Edit: I have tried to adb shell the box and tried the command 'dd if=/path-to-recovery/recovery.img of=/dev/block/recovery ;sync;sync' but no luck...
However is making the FW, most likely Netxeon, is making things worse. They are removing the ability to boot recovery from ExternalSD, and making ADB shell not run has root, they are doing this in a number of devices.
Maybe use a custom FW where this things might be fixed.
I currently don't have any Amlogic device, so don't expect much.
So I made a TWRP backup of an MXQ S805 tv box. Flashed a rom and buggered the device. So no I'm trying to restore in TWRP but I get these messages. It seems I dont have a partition table anymore? How can I restore that?
Block device not present. Cannot wipe System.
I dont have /data /system or /cache partitions.
Thanks in advance for any help with this brick.
JM
Originally posted by abdul_pt View PostTry to flash the stock rom using External SD and stock recovery.
Cant mount /data (and /system and /cache)
Format failed
Wipe Failed
etc etc
Seems as if I have no partition table on internal sd!
Hi Abdul, is the theTWRP 2.8.7.0 N200 correct version for the m8s? it wont let me back up to the sdcard its reads external sd 0mb.
There are currently 2191 users online. 1 members and 2190 guests.
