And i need recovery.log at least. Also remember that backups made with the TWRP version, any one before 2.8.7.0, will not work on this version, 2.8.7.0. Because of the backup of the SDcard.
TWRP for Amlogic devices.
Originally posted by perpetual View PostHi Abdul,
Here you go, stock boot.img and recovery.img from
MBX/k200_MXIII_1G/k200_MXIII_1G:4.4.2/KOT49H/20150619:user/test-keys
Thanks!
Diese Website steht zum Verkauf! freak-tab.de ist die beste Quelle für alle Informationen die Sie suchen. Von allgemeinen Themen bis hin zu speziellen Sachverhalten, finden Sie auf freak-tab.de alles. Wir hoffen, dass Sie hier das Gesuchte finden!
Alternative
You Rock Abdul! Another k200 pwned!
TWRP_2.8.7.0_MXIII_1G.img works like a charm!
boot, recovery, logo, system & data backed up just fine
Cache is showing 0 bytes
Having a TWRP recovery instead of the stock 3e is a god send
Thanks again for your time & work, much appreciated.
I can now try OpenElec on this puppy
How about bootloader ? Did it show ?
Cache is 0 size because it's empty.
Originally posted by abdul_pt View Post
Good.
I used TWRP_2.8.7.0_MXIII_1G.img to flash my k200_MXIII_1G with OpenELEC-Amlogic.MX3.arm-5.0.6.zip
Flashed ok, OpenELEC works fine, both LAN & AP6181 wifi
I decided to try and flash back to stock firmware but it didn't work cause OpenELEC-Amlogic.MX3.arm-5.0.6.zip flashed a new bootloader
My k200_MXIII_1G now had a new dtb of
dtb 2 soc: m8 plat: k200 vari: sdhc
So I used different firmware k200-ota-20150530.zip (Tronsmart MXIII_115k4) to get back to an android OS
No biggie, I'd rather have my MXIII box with a more common dtb of m8 k200 sdhc
It is now flashed with OpenELEC-Amlogic.arm-S82-5.95.2.zip
Would be nice to know how to backup / restore just the bootloader thoughLast edited by perpetual; 23 July 2015, 02:29.
I didn't see the bootloader in cat /proc/partitions
It isn't misc as misc.img in a hex editor is all zeros
How would one go about creating a signed zip package to replace the bootloader.img ?
java -Xmx999m -jar signapk.jar -w testkey.x509.pem testkey.pk8 update.zip update_signed.zip
zipping up bootloader.img isn't going to work
How do you specify the bootloader flash address location if it is a hidden partition ?
Here's a Template - http://expirebox.com/download/5e2b80...b621c7f41.html
Unzip and look inside, use all of the META-INF folder, edit update-script and place the necessaries files in the right place.
You don't need to sign the zip in TWRP.
TWRP 2.8.7.0 N200 emmc -
fyi-not working on t8plus stuck on teamwin blue splash screenLast edited by foz; 02 August 2015, 17:44.
Originally posted by an0ny View Post
Working great on minix neo x8h plus! Thank you!
Does all partitions show available to backup ?
Thanks for the feedback
What was the previous working version if any ? link to the FW would also help if there weren't any previous version
Hi Abdul_pt
yes its the new S812 n200 on rooted stock fw, I've tried using the TWRP 2.8.7.0 N200 emmc as stated above just on sd card to make a back up but it hangs at the blue splash screen.
its on standard system recovery KOT49H.20150414 at present.
no firmware public at present ota updates only.
I've looked but cant see what location the ota downloads fw to or I could ftp it out after downloading the latest version assume it will delete it after installation but I could grab it before installing. if you have any idea of the likely location it will store it I will grab it out.
thanks Abdul_pt
There are currently 2973 users online. 1 members and 2972 guests.
