If that doesn't work, give me a link to the FW.
TWRP for Amlogic devices.
Originally posted by abdul_pt View PostDo you have a working TWRP ? If yes flash SuperSU.zip.
Else upload stock recovery
Is there an working version for MXIII-G. I've tried "TWRP 2.8.7.0 N200 emmc" and it boots to TWRP from usb, but it gives errors like "unable to find partition size" for like all partitions (boot, recovery, bootloader, misc, etc....). Thanks, awesome work
Originally posted by wietje91 View PostIs there an working version for MXIII-G. I've tried "TWRP 2.8.7.0 N200 emmc" and it boots to TWRP from usb, but it gives errors like "unable to find partition size" for like all partitions (boot, recovery, bootloader, misc, etc....). Thanks, awesome work
Originally posted by gurung_vishwas1 View PostThanks Abdul, I rooted with s8xx_root_udate.zip and it works. I want to flash your TWRP, but first trying to find the stock flashable 4.4.2 firmware for my OTT M8S S12 so that in case I mess it, I can always come back to stock. Till now, no success. I asked China supplier from whom I purchased this, he is also unable to provide the firmware. If you know any reliable link, please share with me.
Hi, I tried the TWRP_2.8.7.0_MK808b+.img on my device via sdcard and the screen is mostly overlapping and flickering and incorrect size. Same happens with themes no matter what resolution ... Same effect on 3 different TV's, I have not more to try, Please help ... Thanks
[edit]
Ok, I discovered setting the display options in the system itself also affects TWRP's resolution, Turned of HDMI-Auto Detect and set mode to 720p under display, works a charm
[/edit]
TWRP 2.8.7.0 X8H Plus
GUI crashes / freezes on "reboot", see attachment.
I have to use ADB to reboot the device.
PS: I can't find the device tree on Github or somewhere else, can you please provide a link to the source.
You may only view thumbnails in this gallery. This gallery has 1 photos.1 Photo
Code:cat proc/partitions
Code:ls -l -R dev/block
Device tree is on TeamWin repository. Some updates might be in order
There are currently 2401 users online. 1 members and 2400 guests.
