Why ? What happens ? How ? Who ? .........
TWRP for Amlogic devices.
Originally posted by abdul_pt View Post
Can you post the output of
Code:cat proc/partitions
Code:253 0 512000 zram0 31 0 1024 mtdblock0 31 1 64 mtdblock1 179 0 15558144 mmcblk0 179 1 15556608 mmcblk0p1 179 16 15267840 mmcblk1 179 17 65536 mmcblk1p1 179 18 524288 mmcblk1p2 179 19 8192 mmcblk1p3 179 20 32768 mmcblk1p4 179 21 32768 mmcblk1p5 179 22 32768 mmcblk1p6 179 23 32768 mmcblk1p7 179 24 1048576 mmcblk1p8 179 25 13424640 mmcblk1p9 179 48 2048 mmcblk1boot1 179 32 2048 mmcblk1boot0
Code:ls -l -R dev/block
Code:130|root@NEO-X8H-PLUS:/ # ls -l -R dev/block dev/block: brw------- 1 root root 179, 23 Sep 22 01:45 boot brw------- 1 root root 179, 18 Sep 22 01:45 cache brw------- 1 root root 179, 25 Sep 22 01:45 data brw------- 1 root root 179, 19 Sep 22 01:45 env brw------- 1 root root 179, 20 Sep 22 01:45 logo brw------- 1 root root 7, 0 Sep 22 01:45 loop0 brw------- 1 root root 7, 1 Sep 22 01:45 loop1 brw------- 1 root root 7, 2 Sep 22 01:45 loop2 brw------- 1 root root 7, 3 Sep 22 01:45 loop3 brw------- 1 root root 7, 4 Sep 22 01:45 loop4 brw------- 1 root root 7, 5 Sep 22 01:45 loop5 brw------- 1 root root 7, 6 Sep 22 01:45 loop6 brw------- 1 root root 7, 7 Sep 22 01:45 loop7 brw------- 1 root root 179, 22 Sep 22 01:45 misc brw------- 1 root root 179, 0 Sep 22 01:45 mmcblk0 brw------- 1 root root 179, 1 Sep 22 01:45 mmcblk0p1 brw------- 1 root root 179, 16 Sep 22 01:45 mmcblk1 brw------- 1 root root 179, 32 Sep 22 01:45 mmcblk1boot0 brw------- 1 root root 179, 48 Sep 22 01:45 mmcblk1boot1 brw------- 1 root root 31, 0 Sep 22 01:45 mtdblock0 brw------- 1 root root 31, 1 Sep 22 01:45 mtdblock1 drwxr-xr-x 4 root root 80 Sep 22 01:45 platform brw------- 1 root root 179, 21 Sep 22 01:45 recovery brw------- 1 root root 179, 17 Sep 22 01:45 reserved brw------- 1 root root 179, 24 Sep 22 01:45 system drwx------ 2 root root 80 Sep 22 01:45 vold brw------- 1 root root 253, 0 Sep 22 01:45 zram0 dev/block/platform: drwxr-xr-x 3 root root 300 Sep 22 01:45 aml_sdhc.0 drwxr-xr-x 3 root root 100 Sep 22 01:45 aml_sdio.0 dev/block/platform/aml_sdhc.0: lrwxrwxrwx 1 root root 15 Sep 22 01:45 boot -> /dev/block/boot drwxr-xr-x 2 root root 220 Sep 22 01:45 by-num lrwxrwxrwx 1 root root 16 Sep 22 01:45 cache -> /dev/block/cache lrwxrwxrwx 1 root root 15 Sep 22 01:45 data -> /dev/block/data lrwxrwxrwx 1 root root 14 Sep 22 01:45 env -> /dev/block/env lrwxrwxrwx 1 root root 15 Sep 22 01:45 logo -> /dev/block/logo lrwxrwxrwx 1 root root 15 Sep 22 01:45 misc -> /dev/block/misc lrwxrwxrwx 1 root root 18 Sep 22 01:45 mmcblk1 -> /dev/block/mmcblk1 lrwxrwxrwx 1 root root 23 Sep 22 01:45 mmcblk1boot0 -> /dev/block/mmcblk1boot0 lrwxrwxrwx 1 root root 23 Sep 22 01:45 mmcblk1boot1 -> /dev/block/mmcblk1boot1 lrwxrwxrwx 1 root root 19 Sep 22 01:45 recovery -> /dev/block/recovery lrwxrwxrwx 1 root root 19 Sep 22 01:45 reserved -> /dev/block/reserved lrwxrwxrwx 1 root root 17 Sep 22 01:45 system -> /dev/block/system dev/block/platform/aml_sdhc.0/by-num: lrwxrwxrwx 1 root root 19 Sep 22 01:45 p1 -> /dev/block/reserved lrwxrwxrwx 1 root root 16 Sep 22 01:45 p2 -> /dev/block/cache lrwxrwxrwx 1 root root 14 Sep 22 01:45 p3 -> /dev/block/env lrwxrwxrwx 1 root root 15 Sep 22 01:45 p4 -> /dev/block/logo lrwxrwxrwx 1 root root 19 Sep 22 01:45 p5 -> /dev/block/recovery lrwxrwxrwx 1 root root 15 Sep 22 01:45 p6 -> /dev/block/misc lrwxrwxrwx 1 root root 15 Sep 22 01:45 p7 -> /dev/block/boot lrwxrwxrwx 1 root root 17 Sep 22 01:45 p8 -> /dev/block/system lrwxrwxrwx 1 root root 15 Sep 22 01:45 p9 -> /dev/block/data dev/block/platform/aml_sdio.0: drwxr-xr-x 2 root root 60 Sep 22 01:45 by-num lrwxrwxrwx 1 root root 18 Sep 22 01:45 mmcblk0 -> /dev/block/mmcblk0 lrwxrwxrwx 1 root root 20 Sep 22 01:45 mmcblk0p1 -> /dev/block/mmcblk0p1 dev/block/platform/aml_sdio.0/by-num: lrwxrwxrwx 1 root root 20 Sep 22 01:45 p1 -> /dev/block/mmcblk0p1 dev/block/vold: brw------- 1 root root 179, 0 Sep 22 01:45 179:0 brw------- 1 root root 179, 1 Sep 22 01:45 179:1
Device tree is on TeamWin repository. Some updates might be in order
https://github.com/TeamWin/android_d...ee/android-4.4
Hey Abdul thanks for the work porting TWRP to these devices, i have an mxIII-G (s812/ 2gb ram / emmc running lollipop 102L1) have tried http://www.freak-tab.de/abdul_pt/aml..._N200_emmc.img and it seems to work fine apart from not seeing the external sd card, strange because it booted the recovery from the external sd card, had to copy it to internal to flash recovery to the box, have removed recovery from external sd and booted back into recovery but still no external sd card showing. could only back up boot/recovery/logo/bootloader as was short on space but all seemed to back up ok. recovery log attached.
Originally posted by vel2000 View Post
thanks
Originally posted by marko33 View PostHey Abdul thanks for the work porting TWRP to these devices, i have an mxIII-G (s812/ 2gb ram / emmc running lollipop 102L1) have tried http://www.freak-tab.de/abdul_pt/aml..._N200_emmc.img and it seems to work fine apart from not seeing the external sd card, strange because it booted the recovery from the external sd card, had to copy it to internal to flash recovery to the box, have removed recovery from external sd and booted back into recovery but still no external sd card showing. could only back up boot/recovery/logo/bootloader as was short on space but all seemed to back up ok. recovery log attached.
Witch SDcard is it ?
I had experience the some behaviour using a 2 GB card. If i started TWRP with it inserted it wouldn't be recognized, them i swapped it for a 4 GB card and it was detected. If i inserted the 2GB card again it was detected.
Might be related to the card density and the SDcard reader. Try a SDHC card.
Mount point seems to be correct
Originally posted by abdul_pt View Postgive me the output ofCode:cat proc/partitions
HI Abdul
I have a amlogic m8 m9&m8_v0.92
I am wondering which version twrp is it I need for this.i remember when you first offered twrp on here I had downloaded a zip from your thread that seemed to work all the time. I could load it up from a sd in the standard recovery.
Issue am having is when I download any from the op I rename recovery.img like suggested but it doesn't pick it up on the sd card when I reboot with the reset button held. If I get in to the recovery an then select update from ext it still does not show up any help would be great..
thank you for your time and help
cheers
cheers
From OP
Code:[B]Install method:[/B] - Download your image and rename to recovery.img - Copy the image to your External SD, and boot while pressing the reset button. On TWRP screen select install->images pick recovery.img [B]Alternative method[/B] - adb shell 'dd if=/path/to/recovery.img of=/dev/block/recovery ;sync;sync' [B]Issues:[/B] On booting to TWRP you might get a screen with stripes, or fill with one colour. Just wait around 3 seconds that TWRP curtain will show.
Please try this one - http://www.freak-tab.de/abdul_pt/aml..._X8-H_Plus.img
Do you have an idea what could cause this behaviour?
So I can investigate for myself and compile and test TWRP.Last edited by vel2000; 27 September 2015, 14:12.
There are currently 2008 users online. 0 members and 2008 guests.
