This fixes problems we were having with being able to write to both internal and external SD cards. Also, you have unlimited (sort of) user app space for apps without having to change the EBR files.
So here's what you need to do:
1. Run the flash tool and verify that I got all of the file paths correct. Choose which recovery you want to flash (stock or cwm).
2. In the flash tool, change the mode from "download only" to "Format All + Download"...otherwise you will get an error.
3. Make sure you have a backup of your IMEI number because this flash will totally erase everything except your external SD.
4. With the tablet turned off, click "download" on the flash tool...then connect the tablet via USB and the flash process will start.
5. Once the flash is finished, unplug the USB and turn on the tablet in recovery mode by holding down the vol+ button and power. When you boot to recovery, do a wipe/factory reset. Then reboot the system.
The first boot will take a long time, so be patient.
If you go to settings/storage you will find that the storage structure has changed. Apps will be installed to your internal storage (I haven't found exactly where, yet...but I haven't spent a lot of time looking).
If you have an external SD, you can change the default write setting to the external SD.
This ROM is:
Rooted
Debloated
init.d/busybox support
Google Play Store fixes added
Your choice of stock or cwm recovery.
English as default language
Download
Enjoy!!!!
Please don't forget to donate!!!!!!
