iFive Mini 3GS RileyROM 1.3
I have not experienced that with mine.
Have you installed any app that goes to full screen mode? Something must be getting stuck at boot time.
You might try flashing the ROM again and test each of your apps and see if you can tell which one is causing the problem....but it may never happen again after that, too.
When you flashed, originally....did you change the EBR files to create a bigger app data partition? After that did you wipe/format the userdata partition with recovery?
Another thing to try is to wipe the cache in recovery and see if it solves the problem.Randy
I changed the EBR on 1.2, but during the 1.3 flashing it was all formatted no? I did a wipe yes.
Will let you know if I find something.
Have you tried swiping your finger up from the bottom of the screen?Randy
Originally posted by rrileypm View PostHave you tried swiping your finger up from the bottom of the screen?
Its like when you kill explorer.exe on windows.
Now it came back, I will try reproduce while reading the logcat to find what it could be.
It also could be very specific to my tablet, I ve got strange behavior : can start when cold, auto-reboot when fullcharged and plugged ...
unable to mount /sd ext or emmc ???
First of all thanks for all your hard work. I am a noob but have no problem
with flashing etc.
I have managed to flash rileyrom 1.3 easily and it appeared to work well.
I had the same problem with 'about tablet' that closes settings but not really a major issue, however when I look at my storage it shows phone storage 15Gb available 0.
My SD card seems fine. I went into recovery to have a look and saw that the SD ext card was not mounted or emmc so I tried to mount it in recovery but It won't mount ... Any ideas????? I would like to recover the phone storage??????
On a different subject, as I was unable to repair my imei with mobiuncle, I tried to do it by mtkdroid tools which worked after I gained root through it and manually entered my imei number.. Worked for me.
So you are saying you can't access you internal or external SD card?
On this ROM, the app data is combined with the the internal SD, which makes the partitions a little different. That's why there's only an EMR1 file in the kit. That could explain the change in how things are mounted.
On my tablet, with Xplore file manager I'm able to look at both internal and external SD.
After you flashed the ROM, did you do a wipe/factory reset in recovery? That is supposed to realign all of the partitions properly.Randy
He told me...in the thread...that he received the update OTA. I'm hoping iFive will do a little better job of keeping their download site up to date.Randy
It's true
Originally posted by rrileypm View PostHe told me...in the thread...that he received the update OTA. I'm hoping iFive will do a little better job of keeping their download site up to date.
I didn't even had the time to root it, maybe this is the reason.
Testing...
:-( bad news... before upgrade gps connected in just 6-8 seconds, now it's been more than 10min and nothing...I don't know what kind of upgrade is this that even quadrant shows 4000pts less than before.
I guess I will try to restore the 1.1.0 nandroid backup I did with riley's cwm. I hope it worksLast edited by jackgar; 08-18-2014, 19:07.
Originally posted by jackgar View PostI guess I will try to restore the 1.1.0 nandroid backup I did with riley's cwm. I hope it works
There are currently 3024 users online. 6 members and 3018 guests.
