I received this device some days ago: www.****.com/itm/360860201770
[IMG]http://i.****img.com/00/s/ODAwWDgwMA==/z/lrYAAOxyuR5TYJd6/$_57.JPG[/IMG]
It is a CX-919 clone with RK3188T + MT6622N bluetooth + ESP8089 wifi (V593 model number on box)
The pcb has CYX_809III V5_0 20140510 and looks similar to the one described here: http://www.freaktab.com/showthread.p...N-with-ESP8089
Device info:
I've been trying for days to connect the device to the PC in flash mode and as mass storage device.. I tried 3 PC's, 3 cables and a lot of different ports, with and without powering on DC port, but still no luck.
When I connect from OTG port to PC with micro usb cable, I press and hold the 'fn' button, then insert into USB. This will bring up an 'Unknown Device' that malfunctioned (code 43). There is no PID, or VID, so I can't see anything that resembles a real device. No drivers are installed, and it's impossible to update the drivers to the Rockchip ones. I also tried to install drivers beforehand with RK_DriverAssitant, but it also doesn't bring up the correct device.
I also tried to connect to the pc with the stick already running.. In the following screenshots you can see the options that I selected.. for some reason, it won't connect either, and does not show up as mass storage device or as any other device
My questions:
- What could be the problem? Why is it not detected as Mass Storage Device? when I connect my smartphone to the PC, this always works... Are there any other things that I could try?
- Is there any other way to update the ROM? I tried putting update.img on sd card and mounting it, but this does not give me an update notice in android... Maybe I put the wrong update.img? or should I always get this notice even if the ROM isn't appropriate?
- Because connecting to the PC isn't working, is there any way to root the device without connecting usb cable? I already tried some tools like z4root and towelroot, but they didn't work.
- Is it possible that the device is damaged / bad flash, and how to test this?
Thanks in advance for any help.. I don't know what to do anymore.. The only thing I didn't try is to use the full size usb port (with KEYBOARD MOUSE text in first picture) with a normal full size usb cable, or OTG port with a USB OTG cable + normal usb cable. I've ordered a normal usb male to male cable to see if this will make any difference, but I doubt it.
