Early testing reveals that GPS is working on this version. I haven't had time to test anything else.
I've upgraded the flash tool to v2.2, but I'm still unable to erase IDB on my tablet...hopefully others can do so on their's.
With the version update, you may notice a little bit different terminology on the screens...but it works the same as the previous version.
1. Download the ROM Kit for your version (wifi or 3g).
2. Unzip the kit on your desktop, or wherever you downloaded it.
3. Open the AndroidTool.exe
4. With your tablet turned on, with USB debugging turned off (in settings), plug in the USB cable. Be sure to always use the USB cable that came with the tablet.
5. Make sure the USB drivers are installed for the Rockchip device. (see the First Time User's Guide for details, if you are having trouble)
6. You should see the tablet recognized by "Found One MSC Device" in the bottom of the tool.
7. Click the "Switch" button to reboot the tablet to flash mode. The screen will turn black.
8. Click "LowerFormat". It will count to 100% (very quickly).
9. Click "Run".
10. When the flash is finished, the tablet will boot into stock recovery and will format your partitions.
11. First boot will take a little longer than usual...just be patient and watch the boot animation.
12. Once the tablet boots to the system...you will have a fresh, rooted system to work with.
This ROM is:
Rooted
Debloated
English as default language
init.d support added
Busybox commands added
Google Play Store fixes added
Reboot app by Petrus
Your choice of 2, 6, 12gb user app space (select the parameter file you want to flash)
Thanks to Geekbuying.com for providing me this and many other Pipo tablets to develop.
Download Wifi Only Version
Download 3G Version
Enjoy!!!!
Please.....Don't forget to donate.
