Finless ROM "tweaker" for the Neo X8 stock ROM BETA 008
I'm wondering if someone can clarify something for me.
I have installed Finless 1.0 ROM on my Minix x8-H which is working fine however, I'm experiencing stuttering while watching some videos like some other people here.
My questions are:
Do I have to install Finless Rom "Tweaker" to make the device more stable? (Hopefully it will fix the stuttering??)
If so, do I need to install the "X8_X8H_002BETA8.rar" first and then apply Finless ROM "tweaker" for the Stock ROM or can I skip the stock rom and install the Finless ROM "Tweaker" directly?
1.) Do I have to install Finless Rom "Tweaker" to make the device more stable? (Hopefully it will fix the stuttering??)
2.) If so, do I need to install the "X8_X8H_002BETA8.rar" first and then apply Finless ROM "tweaker" for the Stock ROM or can I skip the stock rom and install the Finless ROM "Tweaker" directly?
1.) maybe yes, maybe not...
2.) yes, first beta and then "tweaker"...
WHAT THIS IS NOT:
This is not a ROM. This ZIP update modifies ONLY the Minix X8 BETA ROM 008 dated 08/09. It does not matter if you installed that BETA ROM from the flash tool or my update ZIP version.
BUT YOU MUST AT LEAST HAVE FLASHED BETA 008!!!!
DO NOT USE THIS ON ANY OTHER ROM!!!!!
WHAT THIS IS:
It is a update ZIP that modifies the Minix X8 BETA 008 08/09 ROM.
Hi guys
I flashed the nexus 10 spoof but still having some apps missing from the play store.
Do I still need to change the ro.product.model to nexus 10?
That should not happen as the install script does not erase. It just replaces build.prop nothing more!
So you must have done something else.
Hi Bob
Thanks for the reply.
I went into the updater app, selected the zip file and updated.
The wipe boxes were not ticked.
Can confirm that I am on beta 008 with tweaker installed.
Not sure if this is is correct spot to post this but could not find any where else. Im runing beta8 with tweeker, cpu fix at 1080 and spoofed as a nexus 10 , I installed th Sunday Ticket App from Direct Tv and is not working propertly, it will let you log in and go to the main menu see the play by play and all games availabe, but it wont stream it just hangs and says Activating and no game. I ask because I also have a RK-42 and it works perfect...any ideas.
Thanks in advance
"With the NFL SUNDAY TICKET App and a subscription to NFL SUNDAY TICKET MAX..."
(http://www.directv.com/technology/mo..._sunday_ticket)
And there could be the problem (like e.g. Amazon Prime, Netflix, (?maybe also SkyGo?)...) because of maybe missing/bad implementation of DRM parts ??? Maybe also because of detecting HDMI-port (because only allowed at tablets without connected HDMI cable)....
Thanks, but found the problem, for some wierd reason this app wont work using ethernet it only works via wifi...got it thanks.
In both XBMC and SPMC i have "audio output device" android, audiotrack and "Number of channels" 2.0 greyed out.
Even my setup is HDMI via reciever... im MX Player pro im able to play 5.1 sound...
where could be the issue?
In Android settings Sound i dont have any options to pick sound device, as i had on X7.
There is only some option to pick sound device (HDMI,SPDIF,PCM) in "SettingsMBox"
No clue what i do wrong
Android devices: Minix X7 (gone) , Minix X8-H , MK808b Plus
Video Out: Benq W1000+ 1080p Projector
Audio Out: HDMI -> Yamaha RX-V467B + 5.1 Yamaha Speakers
Remote: Rikomagic MK702 II, Minix NEO M1
Storage: NAS Zyxel NSA325v2
in system (expert) sound enable passtrough an be sure al the options below that are selected (special the receiver is DTS capable) that works for me.
