ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Yipee!
After fooling with trying via usb - which didn't work - I went and got a SD card reader and VOILA! up and running in about 30 min. Thank you
Anyway - just to make sure its right storage is showing Internal Storage - total space now of 3.94gb 3.71gb available
nand flash total space - 1.55gb available 1.55gb
Why does it not show 8gb anymore? Is it because your new parameters show what is usable? and the system and bloatware don't show up anymore
Thank you so much for all your help
Karen
Karen
The stock parameter settings had approximately 1GB allocated to the "data" partition and almost 4GB allocated to the "internal sd card" partition.
The patched parameters decrease the "internal sd card" partition size in order to increase the "data" partition size, and also move the partitions around to make room for the new "data" partition size.
ShaunMTFreaktab Rom Developer
Problems to Start Tablet
Hello first of all a greeting, I have problems with my tablet, I installed the modified rom, then the TWRP, then the patch to the internal memory of 4 GB put it, did not work and then read that had to flash the ROM from TWRP. After that it worked well but installing games since the tablet is from my daughter tablet without notice went out.
So I thought to reinstall the ROM and patch to the internal memory will be so stock. But now the ROM to try to start in its initial configuration turns off. Any suggestions you could do to recover the tablet, and I have fear and I think I'll have to buy a new tablet, all for sticking my nose into a device that is not mine ha ha ha. Thanks in advance for your help
This text translated it using google translator from Spanish to English
Originally posted by 1976Nano View PostHello first of all a greeting, I have problems with my tablet, I installed the modified rom, then the TWRP, then the patch to the internal memory of 4 GB put it, did not work and then read that had to flash the ROM from TWRP. After that it worked well but installing games since the tablet is from my daughter tablet without notice went out.
Does it currently boot up all the way before turning off? If not, at what point does it turn off?
Does is still boot to TWRP recovery without any problem?
Are you sure the battery didn't suddenly run out of power? This model has a known problem with loose battery cables, resulting in incorrect battery level readings, sudden shutdowns, and poor or no charging...
I hope I have correctly understood the questions. The problems arose when I returned to install the ROM, to start the ROM presents very briefly the initial settings screen where you can configure the wifi, select the country, etc, but before he could take any action the tablet is turned off.
I can enter without any problem recovery, the tablet does not turn off while in the recovery.
On the problem of the battery, something I read it and thought it could be happening because my girl was soon extinguished the tablet. How I can check if the battery is properly connected?
I appreciate your attention and patience
Originally posted by shaunmt View PostIt sounds like it booted normally and seemed to be working correctly until it suddenly turned off? Is that correct?
ShaunMT
Originally posted by 1976Nano View PostI hope I have correctly understood the questions. The problems arose when I returned to install the ROM, to start the ROM presents very briefly the initial settings screen where you can configure the wifi, select the country, etc, but before he could take any action the tablet is turned off.
It does sound like a battery problem to me. I think any other problem would result in failure before you reached the lock screen.
I believe TWRP continues to work because:- TWRP requires less power
- TWRP reads the battery level differently
- TWRP doesn't auto shutdown before the battery reaches zero.
Unfortunately, the only way to check the battery cable is to pop the back cover off the tablet (which can be difficult - the front bezel is easy to bend or crack while trying to remove the back cover). There are several forum posts around here about opening the case the checking the battery.
The battery plug should be firmly and completely seated in the socket. This most often pulls the wires tight across a gap between the battery and the board. Pushing on the wires, flexes them into that gap and pulls the plug partway out of the socket. Some modifications may be necessary to prevent the plug from working loose again.
Well the tablet has been able to start, had withdrawn the External SD Card and went to put it on the tablet, I started new account and I could configure the tablet correctly. The problem is that there has been internal memory as stock (only 832 MB available to applications).
Unfortunately when I installed the patch to extend it to 4 GB, installed applications, would cause the tablet is turned off, any suggestions or think the problem is poorly connected battery? Thank you
ShaunMT
Originally posted by 1976Nano View PostWell the tablet has been able to start, had withdrawn the External SD Card and went to put it on the tablet, I started new account and I could configure the tablet correctly. The problem is that there has been internal memory as stock (only 832 MB available to applications).
If reformatting the /data partition or internal sd card doesn't solve the problem, I'd still go back to checking battery.
Before that i need installa the patch for 4 GB? and so reformating data and internal sd card?
thanx
Originally posted by shaunmt View PostYou could try wiping or reformatting /data and the internal sd card from TWRP to ensure they are formatted correctly and to the correct size (per the currently installed patch).
ShaunMT
Originally posted by 1976Nano View PostBefore that i need installa the patch for 4 GB? and so reformating data and internal sd card?
thanx
If it won't start correctly, reflash the ROM from TWRP (The TWRP ROM installer only flashes Boot and System).
If it starts correctly, check the /data and internal sd card partitions. Verify they mount, their sizes have changed, and that you can read/write to them. If you have any problems with the /data or sd card partitions. Try reformatting them with TWRP.
If you continue to suffer random shutdowns or experience charging problems, take the back cover off and check the battery connection.
Thank you Shaun
Originally posted by shaunmt View PostInstall whichever size patch you prefer (if you haven't already).
ShaunMT
Great Deal
ShaunMT
I just Got Nextbook NX785QC16G which I bought at walmart in canada it comes with 16gb bluetooth and would you believe GPS for $88 CAN. The problem is it needs to be rooted the firmware update is at the Nextbook site if you can look into it and maybe give me some direction in rooting this device thanks
Here is what I can tell you about it... It is a MediaTek (MTK) based device. I'm only just beginning to learn how to develop for MediaTek devices and I'm doubtful that I'll be confident enough to develop for a MediaTek device that I don't actually own and can't test on...
However, rooting it shoudn't be too difficult...
The NX700QC16G was also a MediaTek device and has been rooted. There are also several MediaTek tablets in the MediaTek (MTK) forum section that have been rooted.
In general, it seems that Kingo Root works on most Android 4.2 devices and earlier, while only iRoot or vRoot work on Android 4.4 and newer.
I would start by reading the NX700QC16G rooting thread in this forum, then read some of the rooting threads in the MediaTeak Tablet subforum.
If you need more help, I would suggest posting a response to the NX700QC16G rooting thread, or posting a new thread in the MediaTek Tablet subforum.Freaktab Rom Developer
There are currently 5413 users online. 1 members and 5412 guests.
