ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
I just can't get the case apart. I also can't flash the stock rom. When I try and get to the point of plugging in the USB from computer to tablet to initiate the firmware install with tablet off, instead of automatically installing firmware, the freaktab emblem comes up followed by picture of battery and then tablet turns back off again. Seems the tablet is getting confused thinking it's charging rather than hooking usb.
Think I'm going to end up taking this thing back to Walmart for a refund and then getting the NX700QC16G. I have that one already and flashing it to the stock Nextbook rom that changed to full partition was a breeze and no frcking battery problems of any kind. Even though I have to settle for a smaller tablet, I'm leery now getting another NX785QC8G.
ShaunMTFreaktab Rom Developer
I wish the Nextbook stock rom was a simple image that installed from SD card but it doesn't. Go to the Nextbook site and download the instructions to see for yourself. You have to use their flash tool, point it to the rom scatter txt in the downloaded rom folder, then in the tool hit download firmware, then hook usb to tablet with tablet off which will automatically start the firmware install. Then when it's done, start up tablet to complete the install. Installing the rom for the NX700QC16G is the same way.
Is it possible to take their rom and turn it into a rkimage?
IfIf you are trying to flash parts of the rom then you use the PC and place it in fastboot by plugging it into the PC powering off and holding the power and volume up bottom at the same time until the tablet boots then the screen goes dark. However the stock image is flashed by putting it on a regular microSD card and booting the tab into recovery and installing from there no pc required.
Originally posted by Mike89 View PostI wish the Nextbook stock rom installed from SD card but it doesn't. Go to the Nextbook site and download the instructions to see for yourself. You have to use their flash tool, point it to the rom scatter txt in the rom folder, then hit download firmware, then hook usb to tablet with tablet off to start the firmware install. Then when it's done, start up tablet to complete the install.
Edit: clarification. Make sure you are unzipping the stock rom and placing the update.img on the card not the zip file. Though you can use twrp to flash the zip if you still haveit installed.
Originally posted by Mike89 View PostI wish the Nextbook stock rom installed from SD card but it doesn't. Go to the Nextbook site and download the instructions to see for yourself. You have to use their flash tool, point it to the rom scatter image in the rom folder, then hit download firmware, then hook usb to tablet with tablet off to start the firmware install. Then when it's done, start up tablet to complete the install.
That is not the correct firmware for the NX785QC8G.... The NX785QC8G is a RockChip tablet... they don't have scatter files... they update from stock firmware using an update.img format ROM...
P.S.> I just checked the Nextbook site and the instruction they posted are completely incorrect... the instructions are for a MediaTek based tablet and the NX785QC8G is not a MediaTek tablet... it is a RockChip tablet... I doubt that the firmware update is even compatible... I'm trying to download it, but it looks like it is going to take about 2 hours to download...
Originally posted by shaunmt View PostThose are the instructions for the NX700.... That is how MediaTek tablets work...
ShaunMT
Bottomline... the people at Nextbook have no idea what they are doing...
ShaunMT
P.S. > the firmware file currently available from Nextbook is NOT the same one that was previously available... and it does not appear to be a valid firmware for the NX785QC8G...Freaktab Rom Developer
Originally posted by Micheal View PostWord. This being my second nextbook tab. Efun is a bit "special" in its tech support and documentation. And are not to be trusted until verified by experimentation or external sources.
Crap you're right, I misread the 8G for the 16G. The downloaded rom even says 8G. What a bunch of wankers over there at Nextbook. No wonder it didn't work. Jeez. Fck me. So I guess there is no stock kitkat rom for this tablet. The reason I wanted to change back to it was I was thinking maybe the rooted rom somehow messed up the battery calibration or something as I didn't have that problem before I did it. But what the hell do I know, I've showed, not much.
This battery thing is really an issue now as I have to literally keep the charger plugged in all the time to keep it from consistently turning off when it drops below a 97% charge. So I either try to take the case apart to see if I can solve the battery issue and risk either breaking the case or marring it up to the point on not being able to return it or just take it back to Walmart for a refund (since I've only had it a couple of weeks). Hope they don't boot it up at Walmart and see the Freaktab start up image, heh heh.
Originally posted by Mike89 View PostCrap you're right, I misread the 8G for the 16G. The downloaded rom even says 8G. What a bunch of wankers over there at Nextbook. No wonder it didn't work. Jeez. Fck me. So I guess there is no stock kitkat rom for this tablet. The reason I wanted to change back to it was I was thinking maybe the rooted rom somehow messed up the battery calibration or something as I didn't have that problem before I did it. But what the hell do I know, I've showed, not much.
Originally posted by Micheal View PostReturn it as non working not holding a charge. Chances are they will just check to make sure it is therein the box and do an exchange.Freaktab Rom Developer
There are currently 2086 users online. 1 members and 2085 guests.
