ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by mel4787 View PostAre any of your patches done? If so can I beta test that
When they are done, I WILL PM you some links for testing.
ShaunMTFreaktab Rom Developer
Originally posted by mel4787 View PostOK. So is it possible to use OMA ROM as a base as well or use your ROM for them
I THINK it should work... but you'll have to test it and find out...
If I can get the update script working, this is what it does:
- Backup current /system, /metadata and /kpanic so they can later be restored in a new location
- Install a modified /parameter that does the following:
- Increases /data size
- Moves /system, /metadata, /kpanic and /sdcard to make room for the larger /data partition
- Moves /sdcard to make room for the new /data partition and decreases it's size because it automatically gets whatever space is leftover
- Reboots recovery to load the new /parameter
- Wipes/Reformats the new /data and /sdcard partitions
- Restores /system, /metadata, and /kpanic to their new locations
- Reboots android
So, theoretically, it should work on any ROM that started with a compatible /paremeter, HOWEVER if the current ROM has a bigger /system, /metadata or /kpanic partition then the restore process may not work... in which case it would be necessary to reflash those partitions with a compatible ROM or partition dump...
Battery Update
Yesterday I purchased another of these limited edition tablets. I fully charged it and used it heavily to see what would happen with the battery. Lo and behold it ran down to the 14% warning and I plugged in and recharged. So it seems there isn't a battery issue with this one. This tablet was manufactured in June of this year as was my last one that had all the issues. I'm willing to bet that all the tablets having the battery issues were made in June. If you still have the box check the sticker on the side.
The only issue I have found so far with one is one that has been addressed in other areas of the forum and that is icons disappearing from home screen after every shut down and restart. Switching to another launcher seems to have resolved that issue.
Originally posted by wiseman9871 View PostYesterday I purchased another of these limited edition tablets. I fully charged it and used it heavily to see what would happen with the battery. Lo and behold it ran down to the 14% warning and I plugged in and recharged. So it seems there isn't a battery issue with this one. This tablet was manufactured in June of this year as was my last one that had all the issues. I'm willing to bet that all the tablets having the battery issues were made in June. If you still have the box check the sticker on the side.
Thanks for the update!
FYI
The first 4 digits of the serial number are the month and year of manufacture.
You can also check the exact date and time of your Android system build in the build.prop file.
I insalled the update easily enough. No issues other than battery reporting issues. However I'm currently using Omas 2.1 for the space. Bootstrapping PAs gapps to get playstore working. Hope for a cm ROM soon as I now have a small child and no time to work on it myself. Going to try to strip your update and install via the rktool to try and get the space while preserving compatability if Omas doesn't work the way I want.
Originally posted by shaunmt View PostThanks for the update!
FYI
ShaunMT
Originally posted by wiseman9871 View PostHow do I go about looking at the build.prop file?
or download a build.prop editor app from the market
Note: If you're not using the original stock ROM that came with your device, some build.prop entries may not be accurate...
For example, if you are using one of my ROMs, I've tweaked a few build.prop settings and the build date would be from the stock ROM I started with (usually the latest known stock ROM for the model).
Originally posted by cpshelley View PostShaun I'm downloading your ROM now, gonna give it a try tonight. not sure if it was already posted somewhere and I just missed it, but how do you boot into stock recovery on these devices??
There are currently 1697 users online. 0 members and 1697 guests.
