ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by shaunmt View PostGlad the install went well!
I'm hoping to have ROMs with different size /data and /sdcard partitions ready soon, but I won't release them until they are as easy to install as the current one. Right now, they require a triple reboot to reformat the /data, /cache and /sdcard partitions because the stock recovery doesn't seem to work correctly, and I don't want to deal with support questions that would lead to.
I guess the good news right now, is that you guys will probably get TWRP recovery and new ROMs with different options for data /sdcard sizes at the same time.
ShaunMT
ShaunMT, looks like oma has something new. http://forum.xda-developers.com/show...php?p=55321603
[Root] Nextbook 8 Quad Core NX785QC8G
Gents,<br />
<br />
Found some time to do a quick update to bypass the 8 GB NAND bottleneck <br />
<br />
Mount points are changed which will make up to 32 GB space available for apps and app data. ......
Originally posted by infirno77 View PostShaunMT, looks like oma has something new. http://forum.xda-developers.com/show...php?p=55321603
Gents,<br />
<br />
<br />
It's an interesting idea, and something I knew was possible (you can actually run Android from external SD with the right mods), but I don't know if I'll go this route or not... it definitely won't work for me personally, as I use the external SD card for development and testing. I'd prefer a large internal NAND /data partition and either mounting the external as internal sdcard or swapping the external and internal mount points whenever desired.
It also looks like he's implemented a dual recovery boot with both CWM and stock recoveries... That's a nice trick, but if I achieve my current goals with TWRP, we won't stock recovery anymore.
ShaunMTFreaktab Rom Developer
Originally posted by infirno77 View PostAwesome. Used to do the sdcard /data trick with my old prevail. Just popping it up so you can see. I prefer to use my sdcard for extra stuff like media, so I won't be using this one. I'm on his previous version waiting on your update. I have high hopes!
Originally posted by shaunmt View PostWell, I think Abdul and I just figured out why my TWRP wouldn't load our nand module... compiling currently... Once I get past this issue, I can start adding the Rockchip update support to it, which will make future flashing of rockchip devices incredibly easy!
ShaunMT
Originally posted by mel4787 View PostSo I take that twrp is almost ready?
Sort of... Haven't tested the latest build yet... if it works, it won't be good for much more than wiping, backing up and restoring the usual partitions...
It can't flash install a full rockchip ROM because it doesn't support the parameter or loader files (yet)... I don't know how long fixing and porting those features from the stock recovery might take...
In the meantime, I might release a preview version, but if I do, it will probably be limited to people who know how to flash just the recovery partition via PC.
Originally posted by shaunmt View PostSort of... Haven't tested the latest build yet... if it works, it won't be good for much more than wiping, backing up and restoring the usual partitions...
ShaunMT
Originally posted by mel4787 View Postis there a way to repartition the partition layout like the nexus or other android devices?
Originally posted by shaunmt View PostI'm not familiar with the nexus devices and I'm not entirely sure what you mean, but I believe you can specify anything in the parameter file as long as you do it correctly and update the bootloader command line to match where necessary...
ShaunMT
There are currently 995 users online. 3 members and 992 guests.
