ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by Darkomega View PostAny way to fix this battery graph issue? Tried factory restore and it stays the same.Freaktab Rom Developer
Originally posted by Darkomega View PostBought it used from **** but it came with the original NX785QC8G box so I assume it is.
It happened while doing a Titanium Backup full restore (apps and system data). After rebooting I noticed that something was wrong with the battery graph.
These tablets don't seem to charge properly without the stock charger, at least mine won't charge correctly on any of my Samsung phone chargers...
There seems to be a problem with the way Android reads or reports the battery level... This seems to be a problem in Google's Android code. Some of the Nexus tablets experience similar issues.
ShaunMTFreaktab Rom Developer
Originally posted by Darkomega View PostI'll leave it charging overnight to see if it corrects itself.
Just in case is there a method of re-flashing the custom rom instead of updating/factory restore?
You might want to research the battery problems on the Nexus 7. There are some temporary fixes, but nothing permanent...
I originally flashed it by putting the update.img on the external sd and updated from Jellybean to Custom Kitkat then factory restored to fix the internal sd mount issue. Does factory restore count as a clean install?
Was thinking more along the lines of formatting the 2GB ROM partition then re-flash the custom ROM if that makes any sense. Since I'm kinda new to this rooting stuff I just need a point in direction.
Originally posted by Darkomega View PostI originally flashed it by putting the update.img on the external sd and updated from Jellybean to Custom Kitkat then factory restored to fix the internal sd mount issue. Does factory restore count as a clean install?
It doesn't touch the system partition, because the system partition is assumed to be read only and unchangeable.
The only way to wipe the internal SD (without a custom recovery or PC tool) is to boot android and go to settings, backup & restore, and do a factory reset with the erase sd card option checked.
If you want to do anything else, you'll have to either use a PC flashing tool or reflash the whole ROM.
Originally posted by Darkomega View PostAh ok, thought that Titanium Backup actually screwed something on the system partition but since it's read only memory that wouldn't make sense.Freaktab Rom Developer
Originally posted by Darkomega View PostSo there is a slight chance that Titanium Backup probably did screw something up on the system partition rom due to it being rooted.
I'm guessing you haven't intentionally screwed around with around on the system partition.
Luckily, if all else fails, you can easily reflash a ROM and start over.
Even you somehow screw it up to the point that you can't boot into recovery mode, you can still reflash it from a PC.
Originally posted by kyuketzu View PostWell I got it installed on her tablet and I am still having the Laucher3 problem with not keeping her app icons on the screen. Maybe I should do a factory restore and see if that helps since I installed your kitkat ShaunMT?Freaktab Rom Developer
There are currently 1513 users online. 1 members and 1512 guests.
