ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by wiseman9871 View PostUpdate wont fix it. I still have that issue even using a launcher other than stock launcher..i have to restore frm a backup nearly everytime i restart.
I haven't noticed this issue, but then I haven't had much time to play with my tablet because I'm constantly reflashing it...
ShaunMTFreaktab Rom Developer
Originally posted by wiseman9871 View PostDalvik
I dont know how to change it to ART....lol
Are all apps affected or just certain apps?
Has anyone tried uninstalling the affected apps and reinstalling them or wiping data or factory reset and then resinstalling the apps?
Originally posted by shaunmt View PostWell don't bother... reason I asked is because a lot of apps don't support ART yet...
ShaunMT
Originally posted by wiseman9871 View PostFor me it seems to be mostly user installed apps and ive wiped data and done factory reset and reinstall, reboot and bam!! their icons are not only missing but it shows them as not installed but but when reinstall all the settings etc are just as they were..i dont get itFreaktab Rom Developer
Originally posted by wiseman9871 View PostI sure wish you could find an answer, that and the battery issue is driving me crazy.Freaktab Rom Developer
Originally posted by shaunmt View PostIs it only affecting apps that are stored (or partially stored) on the internal SD card?
Originally posted by wiseman9871 View PostIt seems to be, but still even if i move them fully to internal storage, it never happens the same way twice, sometimes they all load then the next time none load
Application developers code their apps to install in data or sdcard by default and some can be moved back and forth...
I'm wondering if your disappearing apps are being caused by a corrupted internal sdcard partition or if the launcher is scanning the internal sdcard for apps before the internal sdcard partition is ready for use.
Originally posted by shaunmt View PostWhen you reinstall one of the affected apps, open settings, apps, find the app, click on it and look at its storage usage...
ShaunMT
There are currently 1767 users online. 1 members and 1766 guests.
