ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by mel4787 View PostFreaktab Rom Developer
Originally posted by mel4787 View PostHmm you mentioned before you had a nexus rightFreaktab Rom Developer
I used ShaunMT's update.img with no issues. No need to factory reset, internalSD working just fine. Thank you very much. I'm sure when you have a ROM that expands the system partition to 2gb that you'll let us all know! Thats the issue that really drives me crazy. Or maybe there's an easy way to symlink the apps directory to internal or external SD?
Originally posted by nalf38 View PostI used ShaunMT's update.img with no issues. No need to factory reset, internalSD working just fine. Thank you very much. I'm sure when you have a ROM that expands the system partition to 2gb that you'll let us all know! Thats the issue that really drives me crazy. Or maybe there's an easy way to symlink the apps directory to internal or external SD?
I'm hoping to have ROMs with different size /data and /sdcard partitions ready soon, but I won't release them until they are as easy to install as the current one. Right now, they require a triple reboot to reformat the /data, /cache and /sdcard partitions because the stock recovery doesn't seem to work correctly, and I don't want to deal with support questions that would lead to.
I guess the good news right now, is that you guys will probably get TWRP recovery and new ROMs with different options for data /sdcard sizes at the same time.
ShaunMTFreaktab Rom Developer
ShaunMT or anyone coupe questions hopefully not stupid..... Have read thouroghly and either have missed it or am having brain fart..
I already have CWM and OMA's 4.2.2 flashed on my nextbook... have i previously downloaded the update.img file from nextbooks and am currently downloading yours but when i tried to put the img file on my sdcard and selected yes to update... it rebooted into cwm recovery and couldn't do anything. I guess one question is how to get back to stock rrecovery and if not how to flashh the img file then...
Also my nextbook turns off when not plugged in while using it randomly whether it says it is 99% charged or 30%. Doesn't matter.... Have i done something to it by flashing it before.. its only 3 months old...
Sorry if questions are repeated or dumb...
Thanks for all hard work and answers....
P.S. Also does anyone have the original 4.2.2 stock rom to go back too?
The only way I know of currently to revert from CWM or TWRP back to stock recovery, is to extract the stock recovery from a stock based update.img, and flash it directly to the recovery partition using one of the PC rockchip flashing tools. There are several different versions of tools for extracting a rockchip update.img and flashing rockchip partitions. If you want to learn how to do this, you'll have to do your own research.
Eventually, when I release my own version of TWRP, it will either include a feature to flash rockchip style update.img firmware files, or I'll release an update.zip that only flashes the stock recovery.
When the tablet dies, the battery really is at zero %. These batteries are never supposed to discharged below 5 or 10%, but the low battery warning and low battery shutdown never appear because the battery % reported by the system is wrong. The tablet just keeps chugging along until the battery runs out completely.
I am doubtful that this will ever be fixed. There are really only two chances for a fix here... either Google fixes it in their Android source AND Nextbook provides another update (don't count on both of these conditions being met), or one of the custom ROMs like Cyanogenmod, Paranoid Android or OmniRom have a fix for it (i don't know if any of them do or not) and we get it compiled successfully for our tablets.
Found another bug...I think
Originally posted by shaunmt View PostNeither CWM nor TWRP recovery currently support rockchip style update.img files. They only support the more common update.zip files (which don't support all the rockchip firmware parts).
This problem has been reported repeatedly... unfortunately it seems to be caused by a bug in Google's Android source code that causes incorrect battery level readings on some devices, including the Google Nexus 7 as well as the Nextbook NX785QC8G.
ShaunMT
I just noticed that if I'm trying to upload a photo and there is a button to click to choose photo, instead of it opening gallery or where ever so the photo can be choosen, it does nothing.....dont know if this is a website issue or tablet, but I ssem to recall it working before.
Originally posted by wiseman9871 View PostI just noticed that if I'm trying to upload a photo and there is a button to click to choose photo, instead of it opening gallery or where ever so the photo can be choosen, it does nothing.....dont know if this is a website issue or tablet, but I ssem to recall it working before.Freaktab Rom Developer
Originally posted by starzman1701 View Postshaunmt.. but how to flash ur img file when i already have cwm recovery installed?
and thanks for your other answers... i will do some research on that but basically ur saying i could extract the stock recovery from nextbooks img file to summarize.... will look into....
thank you
Originally posted by wiseman9871 View PostJust using the stock browser. It appears it happens on many sites. One I use often is chathour.com it happens there
Doesn't work with Browser...
Works with Chrome...
Probably works with Dolphin too, but I didn't download it to test.
ShsunMTFreaktab Rom Developer
There are currently 3351 users online. 2 members and 3349 guests.
