ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by AMMO View Post
Originally posted by orlandoamg360 View PostWere you on a rooted firmware. Root is necessary in order to flash a recovery. The arctools.apk also requires root. Not sure what went wrong. Maybe a bad flash. I've personally flashed the recovery myself without any issue. And apparently user RosaFang has also done this. I've bricked my tablet many times trying to flash only the parameter file with the rkandroid tool. Reflashing OMA'S rom always got me up and running.
You almost always have to reflash ROM and wipe data, cache and sometimes SD card when flashing a parameter file, because the parameter file changes the locations of partitions.Freaktab Rom Developer
Ok guys. After reflashing OMA'S rom (necessary to remove cwm and restore stock recovery) i updated to ShaunMT's rom with his update.img via the stock recovery . Once I was up and running, I proceeded to install arctools. Its quick and easy to use. Just select OMA'S cwm recovery 6.0.3.1 from the drop down list, hit download, then install. Its that easy. Then just go to reboot tab and select reboot to recovery to access cwm. Make your nandroid backup to external sd. Then, its necessary to reflash OMA'S rom to obtain the new parameters which will format the system, data, and sd card partitions, which is why you must backup to external sd. Install arctools once again and reinstall recovery. Restore backup of ShaunMT's rom. Tedious, i know, but necessary untill ShaunMT can release his repartitioned Roms.
FYI
Some additional ROM options with different /data and /sdcard sizes aren't far away... just doing some more testing and tweaking to ensure that they are easy for everyone to install...
ShaunMTFreaktab Rom Developer
Originally posted by AMMO View PostPM me if you need a tester, I can easily get this thing back to your original update.
At present they install ok, but result in either a bootloop, or an encrypted android login. Either condition requires a manual reboot to recovery to wipe data and cache.
Modifying the install script to properly wipe data, cache, and hopefully sdcard too, should resolve the problem, I just haven't had more time to make the changes and retest yet... maybe after work tonight, but no promises...
Originally posted by Perfectpitch View PostHas anyone tried the disable critical battery shutdown for choose to see how that affects the early battery shutdown situation. I've current have it installed to see what happens.Freaktab Rom Developer
Originally posted by AMMO View PostNot sure if it is because of Oma's ROM or the fact that only 1GB was available on the stock nextbook, but Injustice: Gods Among Us is incompatible. Can anyone with more than a 1GB partition confirm this as well?
The app is only about 83MB in /data... the support files are over a gig but went to /sdcard.
Never played it before... interesting game mechanics... excellent graphics!
There are currently 2067 users online. 0 members and 2067 guests.
