ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by B-Man View PostHow are things going with TWRP?
I do have some updates regarding battery issues though... I'll be posting my latest findings as soon as I finish responding to people.
ShaunMTFreaktab Rom Developer
Originally posted by mel4787 View PostHow are things with twrp and ROM management?
Possible Battery Solution: Check the battery cable connection inside the tablet
While on vacation, I was forced to use my tablet to do college course work because I forgot my laptap power cord...
My tablet would not turn on or charge properly. Normally, I have to reboot to recovery and factory reset or wipe data & cache, but at the time, I had a non-bootable test copy of TWRP installed... I couldn't reflash because my laptop was dead also...
In frustration and desperation, I carefully popped the back cover off the tablet and guess what I found... the battery cable was not firmly plugged in... I unplugged it, plugged it back in firmly and completely... and my battery has seemed normal ever since!
It charges quickly and no longer sticks at 100% before the battery level starts draining at a what I consider a normal rate. I'm still testing draining the battery until shutoff and recharging from that point... I will update results again later.
Originally posted by shaunmt View PostWhile on vacation, I was forced to use my tablet to do college course work because I forgot my laptap power cord...
My tablet would turn on or charge properly. Normally, I have to reboot to recovery and factory reset or wipe data & cache, but at the time, I had a non-bootable test copy of TWRP installed... I couldn't reflash because my laptop was dead also...
In frustration and desperation, I carefully popped the back cover off the tablet and guess what I found... the battery cable was not firmly plugged in... I unplugged it, plugged it back in firmly and completely... and my batter has seemed normal ever since!
ShaunMT
ShaunMT
I'm currently recharging and will try to recalibrate the battery to see if I can get the low end battery level and low battery warning to work correctly.
Originally posted by shaunmt View PostI have one problem remaining with my battery... the low battery warning doesn't appear until 15%, at which point the tablet also dies (real battery level must be zero). Then the tablet won't restart until the battery is charged to 6% (apparently the safety shutoff to protect the battery from full discharge is configured for 5%).I'm currently recharging and will try to recalibrate the battery to see if I can get the low end battery level and low battery warning to work correctly.ShaunMT
Originally posted by orlandoamg360 View PostThat's always happened to me since day one. Now my tablet shuts off at about 50%. At this point, I'll settle for the same results as yours.
Previously... it shutdown sooner each time like yours...
I'm hoping this change will make the recalibration work to fix it fully and permanently (assuming the battery cable connection doesn't work itself loose again).
Originally posted by shaunmt View PostMine is at least consistent now... I've fully charged and fully drained it twice now... exact same results both times...
ShaunMT
Originally posted by shaunmt View PostWell... couldn't turn on again... popped cover off and battery connection appeared loose again... push it in and tablet powered up at 18%... going to have to try taping or glueing batter cable connector to keep it firmly plugged in...
ShaunMT
Originally posted by orlandoamg360 View PostReally? I've dropped my tab a couple of times. Nothing serious. Not enough to crack the screen. I wonder if that somehow contributed to loosening the wire? Or is it faulty by default? By the amount of reports of battery problems, I'm guessing it's a faulty wire. Has anyone else dropped their tab?
I'm planning to try some electrical tape to hold it together... if that fails, I'll use some low temp hot glue on it... either will be easy to peel off in the future if necessary...
ShaunMT
Originally posted by shaunmt View PostWith the cover off, and the battery cable firmly connected... low battery warning pops up when battery changes from 15% to 14%... tablet remains on... currently at 11% and waiting to see when emergency shutdown occurs...ShaunMT
Originally posted by orlandoamg360 View PostYou're a genius bro! I knew you'd figure this thing out!
Currently at 8% and still waiting for emergency shutdown...
I also noticed that one of the 4 wires on the battery cable is taped over the corner of the battery (the one on the end of the connector that pops loose). The extra pressure between the corner of the battery and the back case probably causes it to pull loose... will reroute it before taping / gluing the connector... If popping the case on doesn't cause it to pull loose, I bet just a gentle squeeze in the right spot while holding the tablet would do it...
ShaunMT
There are currently 5207 users online. 2 members and 5205 guests.
