ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by shaunmt View PostYES!
I think it is safe to say that I am VERY close to releasing a whole bunch of stuff...
TWRP works! It turns out that I didn't need to port any features from the stock Rockchip recovery, once I learned how Rockchip was doing things, I found my own workaround that didn't require adding any new features to TWRP.
To give you an idea of how close I am to release... here is a list of some of things that appear to be working:
- TWRP Fix Permissions bug I mentioned previously was fixed by a TWRP source code update.
- TWRP UI Layout has been modified to fit our device screen.
- TWRP backup and restore work for ALL partitions on the device. (Including parameter and bootloader!)
- TWRP Wiping works for ANY partition on the device. (Including /data, /cache, /dalvik and /sdcard which didn't always work correctly in stock recovery.)
- TWRP Flashing works for ALL partitions using standard .zip update files. (Including /parameter to change partition layout sizes and /misc for bootloader!)
So... here's what is left to do...
- Write the scripts for the various update packages.
- Prepare and package the update files.
- Test to verify all the updates are applied correctly.
- Upload the update packages.
- Write up the posts and publicly release the files.
I think it is going to work like this:
- Install TWRP Recovery using stock recovery.
- Backup ALL of your existing partitions. (Or don't... just don't blame me if something goes horribly wrong...)
- Flash the parameter file for your desired partition layout.
- Reboot to recovery and wipe /data, /cache, and reformat /sdcard. (I might automate this.)
- Optional: Flash a new version of my ROM.
- Reboot Android and enjoy!
Stay tuned...
ShaunMT
Originally posted by B-Man View PostGreat news! Did you figure out how to eliminate the internal SD making it all data, and making the external SD the only SD?
Eliminating the internal sd, means changing the mount points in addition to changing the parameter file, which means either adding an init.d script to change them at boot time or a making a different boot image which means a completely separate ROM.
Either solution would result in an internal sd card partition that fails to mount in recovery and a normal external sd card in recovery. I think I would be ok with this, but it could be confusing for users.
I've also considered a /data/media layout where the sdcard is symlinked to /data, making all the space available, but again this requires an init.d script or boot image change. It also results in an sd card partition that gets wiped when /data gets wiped in recovery.
ShaunMTFreaktab Rom Developer
So is tarp fully functional?
Plus what kind of partition layout does this tablet use?
There will be a couple of different options to choose from.
Re: ShaunMT's Modified ROM for Nextbook NX785QC8G (Support Thread)
Originally posted by mel4787 View PostAwesome. Since this tablet came with at least 7gb of storage think you can get that to us
Approximately 5.75 gb is currently split between /data and /sdcard and can be moved back and forth from one to the other.
The rest is divided up between other parts of the firmware and should probably be left alone, although I might take some space from /sdcard to add to /cache.
ShaunMT
Sent from my SM-G900P using TapatalkFreaktab Rom Developer
Originally posted by B-Man View PostAny rough time estimate on the release?
I found what seems to be a bug in TWRP that is preventing the flash of the some of the partitions (including the parameter partition where the partition sizes are located) from working correctly.
I'm currently trying to determine if I can fix it or if I need to work around it... It really needs to be fixed because it could cause other things to fail to install as well.
Originally posted by shaunmt View PostI was hoping for this weekend, but it's probably not going to happen.
ShaunMT
Originally posted by B-Man View PostOk thanks for everything, keep up the good work, we'll hang tight, and let us know if you need anything from us. Good luck.
Until then, thanks for everyone's patience.
It's going to be worth the wait!
There are currently 1809 users online. 0 members and 1809 guests.
