v1.3 is based on an official Pipo firmware update dated 8/25/2014 (#126).
v1.4 is based on an official Pipo firmware update dated 8/26/2014 (#130).
I've tested these ROMs on my P9 and I've encountered no problems. The file name of the #126 update indicates it fixes some issues with WPS. The file name of the #130 update says they've improved battery charging detection.
Since this is a wifi only ROM, I've started experimenting with a handful of battery saving tweaks that are intended to eliminate 3G services from running in the background...which has always been a problem with these wifi only tablets getting a good deep sleep configuration.
With the stock launcher last night I broke 41200 on the Antutu benchmark and a 350 stability rating. The rating decreases with Apex Launcher.....but it's still pretty fast.
This ROM is:
Rooted with SuperSU
Debloated of unnecessary apps (There really aren't many to begin with)
Busybox/init.d support added
Google Play Store fixes added to allow more apps to be compatible (it works)
Your choice of 2, 4, 6, 8, 10 or 12gb user app space by selecting the desired parameter file
Download v1.3
Download v1.4
Edit: At the request of some P1 users, I've started activating the Multi-User feature in these RK3288 ROM's. Here is v1.4.1 for the P9 with working Multi-User.
Download v1.4.1
Here is version 1.5...based on firmware dated 9/11/14.
Download Wifi Version (now 1.5.1 with working TWRP)
Download 3G Version (now 1.5.1 with working TWRP)
Abdul_pt has provided us with a TWRP recovery for the P9:
Download
Just uncheck everything except the recovery line in the flash tool, browse to where you've downloaded this file, and flash it by itself. No need in erasing IDB.
Enjoy!!!!!! Don't forget to tip the developer...hahaha!!!!!!
