Maybe It's working, don't know !
Pipo P4 RileyROM 1.6 [RK3288]
Re: Pipo P4 RileyROM 1.6 [RK3288]
Originally posted by locutus2000 View PostInstalling nowThank you for removing the advertising from the Boot logo. Could it be possible titanium backup doesn't backup to external_sd by default?
Google now launcher will not run again this time, did you change the CHMod of the libril file?
2. You have go into preferences in Titanium to change it.
3. I'm not sure what is causing the launcher to fail.
4. The permissions should be set to 755 on the libril file.
Sent from my P1 using TapatalkRandy
I'm not exactly sure of the results if you flash Gapps with TWRP...just make sure you have the most current versions. Let's see if we can get a working TWRP.Randy
Abdul, I don't recall you doing one for the P4, yet. If so, I must have forgotten.Randy
Randy
bricked?
HI all,
i flashed my P4 with the 1.6 rom yesterday evening
all with default values, everything went ok, booted and tablet was working fine , installed some bascic apps.
I let the tablet charge overnight and now it won't turn on anymore
nothing, not after reset , no recovery ... no pc detection
any ideas what happened and what I can do about it
UPDATE
AND it's dead again, charged to 83% max . then switched off and no way to get it back on !!
I feel the same, all roms based on 4.4.4 this occurs, with 4.4.2 not fails me.
Just for that I went back to 4.4.2 because I use facebook much.
Originally posted by rene90 View PostSmall bug i found, in the facebook app i got this when i see a movie on the timeline / click on it:
Others got the same?
Originally posted by biri80bcn View PostI feel the same, all roms based on 4.4.4 this occurs, with 4.4.2 not fails me.
Is there not a reset button on the back of the tablet? You can push that instead of unplugging the battery.Randy
There are currently 2578 users online. 0 members and 2578 guests.
