ENY EM8 Android firmware by Stane1983
    here's my first Android release for ENY EM8 device.
    Version 2014-09-03
    - Kernel 3.10.53
    - Rooted (SuperSU)
    - Based on latest Amlogic SDK (2014-08-23)
    - XBMC 13.2 included
    - wifi/bluetooth/ethernet working
    - real sleep
    Download under Firmwares tab.
    I need feedback. M8 device I have is older one.
    If you find my work useful, buy me a beer
    Homepage: http://www.stane1983.com
    Originally posted by stane1983 View Post
    Version 2014-09-03
    - Kernel 3.10.53
    - Rooted (SuperSU)
    - real sleep
    Would this be compatible with my box or would I be looking at another brick?
    Android version 4.4.2
    Build Number
    KOT49H.20140813
    Kernel Version
    3.10.33
    ubuntu@kitkat #1
    Mon Aug 25 12:16:28
      Build Number
      KOT49H.20140813
      Kernel Version
      3.10.33
      ubuntu@kitkat #1
      Mon Aug 25 12:16:28
      Well.... i don't know which box you have so I cannot answer This firmware is for square box.
        Yes its the square box but finless rom was for the square box and that worked on one but bricked another
          I can only tell you to try on your own risk. FW is using latest kernel, android and uboot sources. But with shiningworth and their products you never know...
            I'll be back in 10 min with either a brick or a review!
              Ok installed ok, on first boot said installing apps total 84,
              No xbmc has installed
                Upgrading apps you mean. XBMC not installed probably because you did manual install, you did not wipe your data partition. XBMC is same as on my page, you can install that one.
                  Yup ugrading apps, I did a toothpick install does your fw not wipe the data partition?
                  another thing I've noticed is the chinese charecters pop up above the keyboard when your typing never seen that before?
                    Forgot to replace keyboard.... And yes, .aml file should have command for wipe data and cache partitions... strange
                      Installed your 13.2 from your site, opened up but it crashes or reboots the box after a few seconds.
                      Going to try a full install again could be have been a bad one
                        [QUOTE=stane1983;222840]Hi,
                        Version 2014-09-03
                        Well.....after a few install errors Bloody %^$& SD card
                        Grabbed a better SD card...
                        Straight in did the basic time date local using HP Dongled KYB and Mouse..
                        All easy.......
                        Installed Google.....installed apps etc wifi good...
                        Plex I use so easy as streaming.....
                        More apps in ok
                        Netflix in Dns ...same as rest of the roms play back wise
                        39200 in AnTuTU if that means anything...
                        XBMC in don't use it ....installed a few movies etc all ok....so far...
                        Free memory holding Menu button on remote, Widgets, Wallpapers and settings
                        More Testing
                        Cheers
                          Does the kernel include drivers for gamepads like Sony (hid-sony) or xbox 360 gamepads (xpad)?
                          If not, I can try to compile some modules since it seems the kernel is available in your github.
                          is meson8_k200a_2G dtd needed I guess? I have never compiled amlogic with device tree structure, only old amlogic 3.0.50 used in mx, but I wanna give a try.
                            Not working for me second install did install xbmc but android locked up shortly after starting up
                              No, I did not include these drivers, but will add. For building modules you don't need dtd (however, it's altered k200b_2g_4k2k.dtd). Kernel on github is GPL released, I'm using non-gpl kernel that comes with sdk. I did not check, but think that there is slight difference.
