ENY EM8 Android firmware by Stane1983
    Originally posted by Zahir View Post
    No worries - I have recovery back. Must have been a glitch in my SD card.
    If you do uprate the ethernet buffers, I'll go back to your rom in a flash - no pun intended..
    you are correct Zahir - I'm growing grey hairs with download speeds as I age
    but then again web browsing is screaming down but aptiode and google play store downloads are slow so not sure if it nand issue or more bit confussed maybe because it 4am and I need sleep
    JustMe
    Bugs are Sons of Glitches!
    JustMe
      Thanks Stane,
      Installed no problem yet will post anything I see
      Originally posted by stane1983 View Post
      here's my first Android release for ENY EM8 device.
      Version 2014-09-03
      - Kernel 3.10.53
      - Rooted (SuperSU)
      - Based on latest Amlogic SDK (2014-08-23)
      - XBMC 13.2 included
      - wifi/bluetooth/ethernet working
      - real sleep
      Download under Firmwares tab.
      I need feedback. M8 device I have is older one.
        Although you can now select location in latest sdk. Im guessing we still dont have working weather?
        Version 2014-09-03
        - Kernel 3.10.53
        - Rooted (SuperSU)
        - real sleep
          Although no issue with installation the pre Installed xbmc keeps closing every time I try to launch. Going to try another xbmc and see what happens.
          Edit:
          XBMC for some reason didnt like the fact I had my setting set @ 720@60hz even though thats what my tv is. Changing to 1080/60hz seems to have resolved closing of xbmc issue.
            Not following... Yahoo weather implementation is not part of sdk. What errors do you experience?
            If you find my work useful, buy me a beer
            Homepage: http://www.stane1983.com
              New firmware now has location which currently has New York as default but when you add your location it doesnt show anything else or acknowledge your location.
                Hey, its still not perfect... Some locations are unknown for yahoo weather My location (Varazdin, Croatia) is shown...
                  Hey no problem... Just saw that was new feature in this but I dont really need it
                  Edit:
                  Just after a short time of using its feels more 'snappier' than usual
                    Great boot up very quick at start, and snappy
                    Installed a couple of weather apps one picked my location. (switched on location)
                    Sleep
                    Goes to sleep and wakes with remote
                    Using remote (one supplied with unit).
                    After wake remote would not respond with +/- volume, WiFi lost after wake, App store no response.
                    Then System locked up and started at MBOX logo and stayed there many minutes and booted.
                    Did a few time to confirm
                    Cheers
                      Bravo Stane prvi si !!!i hope we will help u to make grate rom wih superb xbmc ,i will test ,ty
                        Re: ENY EM8 Android firmware by Stane1983
                        Any possibility we could get this box to shutdown or something similar to finless?
                        Sent from my Minix Neo X8-H using Tapatalk.
                          Can you explain that little more? I have to admit that I did not try finless fw
                            He had a apk that could shutdown, reboot M8. No option for on here. So basically you just have to unplug it.
                            But so far everything else is working really well.
                              Stane, I did not do the power button fix. It was in ENY's last firmware. As I recall it was a .lib file that had changed (I did a kdiff3 between old and new ROM). Right now I do not remember what the lib file was anymore. But without their sources good luck!
                                Thanks finless
                                But for sure this is great work so far Stane. I'm a big fan
