Sent from my Minix Neo X8-H using Tapatalk.
ENY EM8 Android firmware by Stane1983
Originally posted by Finless View PostStane, I did not do the power button fix. It was in ENY's last firmware. As I recall it was a .lib file that had changed (I did a kdiff3 between old and new ROM). Right now I do not remember what the lib file was anymore. But without their sources good luck!
Anyway, power key must be linked to code 704 (thats whats changed).
Originally posted by trebor View PostWhen It wakes as mentions it locks/stops responding here...
Drops to MBOX reboot takes about ~2 minutes+ then returns
Not a big deal for me I just Power off at plug.
Cheers
Sleep
Goes to sleep and wakes with remote
Using remote (one supplied with unit).
After wake remote would not respond with +/- volume, WiFi lost after wake, App store no response.
Then System locked up and started at MBOX logo and stayed there many minutes and booted.
Thanks Stane Great Build
No interlacing problem really fast and responsive but This Wake Lock ups Leads the box to Reboot and box Stucks @Reboot screen ...
The only option is Plugging Off the box from the Mains Power to restart the box...
real deal breaker so Sad to see another build with a major problem
Re: ENY EM8 Android firmware by Stane1983
The only box I have that sort of works right is the Minix x8h.
Originally posted by tampametal View PostKind of a weird issue and don't know if it's just here but when exiting xbmc using pre installed stane xbmc, the exit button is invisible... Anyone else have this issue?
Weird
Originally posted by trebor View PostNew to XBMC but if you are talking about the Off symbol L/H corner I see mine maybe you telly changed res and its off screen.
Originally posted by tampametal View PostNo... when you shutdown xbmc the exit box that comes up on middle isn't there.
are your sure----YES
Unless you mean something else that I am yet to find out about
Cheers
[QUOTE=JustMe;223027]Originally posted by trebor View Post
Trebor
I would have Conjunctivitis by now if i got those scores realistically
JustMe
Originally posted by tampametal View PostEvery Android box I have tested has issues turning on/shutting down. Such a basic issue to have such a problem.
Sent from my Minix Neo X8-H using Tapatalk.120" screen, EPSON 6100W, YAMAHA RX-V775, B&W 603 (front), B&W CC3 (center), B&W DS3 (surround), Boston Acoustics SoundWare XS (front heights), SVS SB-2000 (subwoofer)
M8 TV Box Codesnake's OpenElec 6.0.3
Tronsmart MXIII+ (v108L1) + KODI 16.1 (Jarvis)
Originally posted by stane1983 View PostCan you explain that little more? I have to admit that I did not try finless fw
The fix was on Life forces roms then was incorporated into the acemaxes roms 22/07/2014
JustMeBugs are Sons of Glitches!
JustMe
There are currently 2103 users online. 2 members and 2101 guests.
