Mx box fuse??
Could be... maybe a thermal-fuse like at coffee-machines and so on... or a normal fuse...
But if I read about "no video" at the MX here at the board, normally it's a problem with bad flashing fw and/or wrong fw...RK3288 Devices
- Overview BOX (LINK !)
Originally posted by no_spam_for_me View PostCould be... maybe a thermal-fuse like at coffee-machines and so on... or a normal fuse...
But, why should they place a normal fuse near to the soc and not direct at the power-plug????RK3288 Devices
Originally posted by no_spam_for_me View PostBut, why should they place a normal fuse near to the soc and not direct at the power-plug????
Yes, I had also seen it in the past at my device, but what I'm wondering in is, that it seams so that both pins contacted to one side of this part and not one at each side (which would be normal at a normal fuse)...
Anyway I don't really know what it is (because I wrote 'Could be...' only speculation that it maybe is a thermal-fuse)...RK3288 Devices
Originally posted by piperider View Postthey look separate in the pic save it and blow it up theres 2 wires separated close but theres a space anyway I need to figure it out somehow as I need this box running as soon as I can there has to be someone who has one with this part that can see what it is or etcMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
Originally posted by clarkss12 View PostIf it is a fuse, just short this two wires. See if it boots with the wires shorted. BUT, if it is not a fuse, then you may damage something else.
Originally posted by piperider View PostI was thinking that but as it is right now I got 2 dead jynbox m6 and now this box so im hesitant to try that.I find it strange that nobody knows what it is if I had another MX here id take it part and check but I dontMK818B, T428, ATV 1220, CS918S, TV01, S89H, R89, ADT-1, MK808B Plus, MINIX X8-H Plus, Tronsmart Orion R68
1. Fuse
2. Oscilator
desolder it and use a ohm meter on continutity to see if the path still works or if it thermal heat fuse then warm it up
JustMeBugs are Sons of Glitches!
JustMe
There are currently 2296 users online. 0 members and 2296 guests.
