Mx box fuse??
    Originally posted by Cathode View Post
    I may be wrong, but i've googled and found S802 cpu boot log where the xtal value is detected as 24000000, which means 24Mhz.
    But i must admit that non-working quartz is a frequent failure on wearable and easy droppable devices like USB flash, not the tv boxes that mostly stands on the rack.
    Does it matter if here Cylinder type?
      Nope. If you can fit it there, it will be ok.
        Thanks man I really appreciate the help I ordered 2 I,ll post back if it works now on to the jynxboxes again see if I can get one of those working
          Come on Guys some take picture or read the value of the part and help this member give life back to his box
          JustMe
          Bugs are Sons of Glitches!
          JustMe
            Some thread related news.
            I've opened my S802 box to see this crystal and found no marks on it except "EAMJ" mark which means nothing but manufacturer mark.
            Then i've measured it to try to find the package type and thus the datasheet. It is 6.9*1.4mm.
            What i've found was these types of xtal:
            - SSP-T7-F;
            - SMLF-145;
            - ABS-13.
            Any of these crystals in that specific packaging are made for only one specific frequency - 32.768KHZ without exceptions. So i guess my thought about 24.000 based on boot log may be wrong.
            Anyway, one of these values - 24.000 or 32.768 is correct. According to the price of the xtal (less than $2) it won't be a big problem to buy 2 and check by yourself.
              - SSP-T7-F;
              - SMLF-145;
              - ABS-13.
              [ATTACH=CONFIG]7916[/ATTACH]
              ok thanks well I ordered 2 24s hopefully that works if not I,ll order a 32 thanks again
                well I finally decided to try the old box again the crystals you recommended did not work I think I need an exact match anyways I found something interesting out from trying numerous things first off if I boot up with any of the crystals it just freezes ar the first screen but where the crystal is soldered if I jump a screwdriver across the wires for a second and remove it the box boots and runs fine im so close I can taste it im so close just need to figure out what needs to be soldered there.i added some pics really need some help with this one.
                  I got a hold of a working box to try to find out what chip was gone but it has some crappy coating over it heres a pic
                    Looks fried or glued just like yours on the first page! IMO
                    O do not own tje box, just speculating. Good luck, maybe try the other frequency: 32.768?
                    Inviato dal mio Nexus 5 utilizzando Tapatalk
                      is not fried its some kind of glue I did try that freq to
                        the box works perfect only for that part
                          Ok thanks to those who helped wish someone who had one of these boxes would have tested this osculator for the MHz but guess those who had one of these didn't want to help anyways I appreciate those who did I finally got the box fixed I actually got the exact part it wasn't an easy task but I found someone from china who helped me out.It is a 32.768 kHz crystal osculator I really hope this helps someone and if you have this issue message me and I will help.
                          http://www.****.ca/itm/191211033770?...84.m1497.l2649
