The not powering up sound worrying, I'm thinking it my not be charging. if you get that tab into mask mode so the flash tool recognises it and leave it for 10 minutes is it still recognised?
Don't Panic! When flashing goes wrong.
Have you flashed this tab from this PC before?
The not powering up sound worrying, I'm thinking it my not be charging. if you get that tab into mask mode so the flash tool recognises it and leave it for 10 minutes is it still recognised?900Supersport
freaktab developer
Hi 900supersport
Thanks for the quick reply, really appreciated
I was using your ROM on this tablet, everything was working fine (except the bluetooth option that was unavailable in the settings area).
Tablet is correctly detected by PC when connected and put into MaskROM flash mode. There is the sound from my W7 computer that indicates that tablet is correctly detected
When I use your flash tool for installing your ROM, it says "Found RKAndroid MaskRom Rock USB". However, when I try to erase NAND (IDB), for example, your flasher says "Error: Must choose Loader for erasing", and there is no "loader" file inside your Zip ROM archive
When I use the official RK Batch Tool, I see the dark-blue square (tablet is correctly put into MaskROM mode), and I can start the Restore function when I select an official firmware;
Here is what I get from this official RK flash tool:
"Download boot start... Download boot success"
"Wait for MaskROM... MaskROM success"
"Test device start.... Test device success"
"Check Chip start... Check chip success"
"Get flashinfo start... Get flashinfo success"
"Prepare IDB start... IDB start success"
"Download IDB start... Download IDB success"
"Reset device start.... Reset device success"
"Wait for loader start... Wait for loader FAIL"
I didn't think the mini had Bluetooth.
I'll see about getting the loader uploaded for you for my ROM. Is it the jelly bean or ICS you have?900Supersport
freaktab developer
Originally posted by 900supersport View PostI didn't think the mini had Bluetooth.
I hope the loader could help, I suppose it might, and I should probably give it a try
Thanks again 900supersport.
Nick.
OK I'll get the boot loader uploaded for you. The jelly bean version of my ROM is available too.
Will post soon with the link, have to go to start up my laptop and fin the files.900Supersport
freaktab developer
Originally posted by 900supersport View PostOK I'll get the boot loader uploaded for you. The jelly bean version of my ROM is available too.
I'll keep you updated too, of course, and will send back tablet if it does not help.
try this.Attached Files900Supersport
freaktab developer
I think the problem is most likely that the battery is not charging. If it's changed it should be at close to 4.2v discharged would be about 3.6 I think.
Try just having boot loader selected and erase IDB just in case.900Supersport
freaktab developer
Originally posted by 900supersport View PostI think the problem is most likely that the battery is not charging. If it's changed it should be at close to 4.2v discharged would be about 3.6 I think.
I tried with a multi-meter, says battery is at 3.99v, so should be fine..?
I also tried to unselect all files except loader and started to flash again. It flashed the file, then says "start to reset device... Reset device OK... Run OK".
Re: Don't Panic! When flashing goes wrong.
Can you now erase IDB?900Supersport
freaktab developer
So does it reset automatically after Erase IDB? If not and it's still detected, clear boot loader check and check kernel, boot, system etc and flash.900Supersport
freaktab developer
Originally posted by 900supersport View PostSo does it reset automatically after Erase IDB? If not and it's still detected, clear boot loader check and check kernel, boot, system etc and flash.
However, in order to get each file flashed (parameter, misc, kernel, boot, recovery, system), I have to select the Loader that you kindly uploaded (if loader is not selected, the flasher refuses to flash all other files). And when I flash loader, unit resets a few seconds after flash procedure is started.
Ok if you cannot erase IDB then flash without bootloader I can only suggest two things, both clutching at straws;
1 try a fresh download, say my jelly bean
2 try flashing from a different PC900Supersport
freaktab developer
There are currently 1963 users online. 0 members and 1963 guests.
